Just now, jbird72 said:
Yeah prez said dont be surprised if initial timing isnt high and total possibly north of 36..3000 good to know  was gonna do 2500..
So what I was gonna do was set the initial timing. And then tune carb, and then the total timing
  • Like 5
21 hours ago, jbird72 said:
I thk overcarbed but i thk i can rejet to compensate dunno yet
Elevation does play a big role in your carb jetting.....
Montelishi's carb was tuned for close to sea level, so being up here near the mountains really changed things.
Makes sense. Stillnhave to get that all mounted and tuned to run proper vac
Holley, like Edelbrock, has a jetting chart that could be of some help setting them up for all conditions.
Assome. Hey can yu read my post in oil pump II..havn a heck of time gettin motor out a lil without car wanting go with it
Nevermind got it!!
33 minutes ago, Scott S. said:
Stuck in the motor mounts ????
I got her up, Scott, but she didn't get as high as I thought. Good thing I did. The one of the motor mounts is f****** loose as %$/_ i think I'm gonna have to take the mounts off the motor to get a 2 / 4 on there. So it sits on top of the frame, or else I was thinking, if I get a hardened bolt to go through the eye holes on the motor mounts, it should get me high enough up.I would hope to pull the oil pan.I don't know yet
In other words, I need to replace the motor mount, so it was a good thing i'm doing all this
That's the "joy" of tinkering with old cars.....
Once you start, you'll never stop. ;)
I've got a collection of 2x4 and 2x6 chunks just for occasions like the one you're enjoying.
Just make sure everything is solid before you get to far into the job.
If one motor mount is bad, then the other won't be long for the world either. I'd just change them both now, and hopefully you won't have to worry about them again.
Yeah, it's pretty crazy because the one is like ovald, so definitely going to change both even on the mount on the frame
