I'm gonna change the name of this, but remember, it started with a simple oil pump or oil PAN. Well. Now let's start now, I gotta pull the motor it's a good thing because I believe the fly wheel is chipped in certain spots. Anyway, look at the conundrum, I have now dont reach. Fml now gotta go rent one prolly
  • Sad 1
There’s another post on the site where someone made an extension. I believe 2x2 square stock. Or they took the existing one off and put a longer one in place of it. If you extend it make sure it goes far into the original lift.
Watch the hood when lifting it gets really close.
Another 30-40-50 bolts and you can have that core support sitting on the ground. Easy peasy. No not really, just messing around.
Prolly gonna pull hood and see if can get from side
All started with carb change
  • Haha 2
You may be able to but that’s a lot of height to get over the fender. It get really tippy too.
Remember years ago she was pulled and able to pull with a dimilar picker just had longer boom. Wonder if one for a deisel motor would work. I can rent
Like prez says 8 more bolts
be carefull about makeing the boom longer without makeingthe legs longer will get heavy and tip over. Voice of experience almost, we saw the lift raising and dropped the motor back down before a diaster happened
  • Like 5
I pulled the hood, and removed and re-installed from the side
Yu have a bbc ?
9 minutes ago, jbird72 said:
Yu have a bbc ?
I don’t believe he does. But I’ve only seen his car once and he only opened the hood for 3 1/2 minutes. Didn’t want no dust on it.
  • Haha 4
Noce
4 hours ago, cny first gen 71 said:
Not sure about Marks but Bob's is a small block. Big small but a small block.
Here we go. Done f'n round the rental place had 1 hoist. Arm wasnt long enough. Dont wanna buy 400 hoist so here we go. Plus if i wanna hang myself after all this be easy
I was just thinking that might be easier.....  ;)
Imagine if you were only starting with changing the plugs. :k
  • Haha 3
Something to be said for a garage with a 9' open joist ceiling.... The car isn't so tippy and easy to roll back in the garage.  ;)
  • Like 5
Posted (edited)
Holy crap!! What is anchoring that cross bar? Might want to rethink that! But, it's outta there, that's what counts!
Edited by 420ponies
Added content
2.. 2 by 6. ..only 3 ft ish apart screwed in with 3 on each side framing screws.ill send yu pick. There same hold as lag bolt  Put strut on top figured better than screwing to bottom.
Actually puy new cross bars in for the winch
