jbird72 Posted June 5 Posted June 5 I'm gonna change the name of this, but remember, it started with a simple oil pump or oil PAN. Well. Now let's start now, I gotta pull the motor it's a good thing because I believe the fly wheel is chipped in certain spots. Anyway, look at the conundrum, I have now dont reach. Fml now gotta go rent one prolly 1 Quote
Dtret Posted June 5 Posted June 5 There’s another post on the site where someone made an extension. I believe 2x2 square stock. Or they took the existing one off and put a longer one in place of it. If you extend it make sure it goes far into the original lift. 2 Quote
Dtret Posted June 5 Posted June 5 Another 30-40-50 bolts and you can have that core support sitting on the ground. Easy peasy. No not really, just messing around. 3 Quote
jbird72 Posted June 5 Author Posted June 5 3 minutes ago, Dtret said: There’s another post on the site where someone made an extension. I believe 2x2 square stock. Or they took the existing one off and put a longer one in place of it. If you extend it make sure it goes far into the original lift. Prolly gonna pull hood and see if can get from side 4 Quote
jbird72 Posted June 5 Author Posted June 5 Just now, jbird72 said: Prolly gonna pull hood and see if can get from side All started with carb change 2 2 Quote
Dtret Posted June 5 Posted June 5 You may be able to but that’s a lot of height to get over the fender. It get really tippy too. 3 Quote
jbird72 Posted June 5 Author Posted June 5 13 minutes ago, Dtret said: Another 30-40-50 bolts and you can have that core support sitting on the ground. Easy peasy. No not really, just messing around. Remember years ago she was pulled and able to pull with a dimilar picker just had longer boom. Wonder if one for a deisel motor would work. I can rent 1 Quote
jbird72 Posted June 5 Author Posted June 5 46 minutes ago, jbird72 said: Prolly gonna pull hood and see if can get from side Like prez says 8 more bolts 1 Quote
Leghome Posted June 5 Posted June 5 be carefull about makeing the boom longer without makeingthe legs longer will get heavy and tip over. Voice of experience almost, we saw the lift raising and dropped the motor back down before a diaster happened 5 Quote
DragCat Posted June 5 Posted June 5 2 hours ago, jbird72 said: Prolly gonna pull hood and see if can get from side I pulled the hood, and removed and re-installed from the side 4 Quote
jbird72 Posted June 6 Author Posted June 6 14 hours ago, DragCat said: I pulled the hood, and removed and re-installed from the side Yu have a bbc ? Quote
Dtret Posted June 6 Posted June 6 9 minutes ago, jbird72 said: Yu have a bbc ? I don’t believe he does. But I’ve only seen his car once and he only opened the hood for 3 1/2 minutes. Didn’t want no dust on it. 4 Quote
jbird72 Posted June 6 Author Posted June 6 15 minutes ago, Dtret said: I don’t believe he does. But I’ve only seen his car once and he only opened the hood for 3 1/2 minutes. Didn’t want no dust on it. Noce Quote
cny first gen 71 Posted June 6 Posted June 6 Not sure about Marks but Bob's is a small block. Big small but a small block. 1 Quote
jbird72 Posted June 6 Author Posted June 6 4 hours ago, cny first gen 71 said: Not sure about Marks but Bob's is a small block. Big small but a small block. Here we go. Done f'n round the rental place had 1 hoist. Arm wasnt long enough. Dont wanna buy 400 hoist so here we go. Plus if i wanna hang myself after all this be easy 3 Quote
Scott S. Posted June 6 Posted June 6 22 hours ago, jbird72 said: Prolly gonna pull hood and see if can get from side I was just thinking that might be easier..... 3 Quote
Scott S. Posted June 6 Posted June 6 22 hours ago, jbird72 said: All started with carb change Imagine if you were only starting with changing the plugs. 3 Quote
Scott S. Posted June 6 Posted June 6 Something to be said for a garage with a 9' open joist ceiling.... The car isn't so tippy and easy to roll back in the garage. 2 Quote
jbird72 Posted June 6 Author Posted June 6 29 minutes ago, jbird72 said: Here we go. Done f'n round the rental place had 1 hoist. Arm wasnt long enough. Dont wanna buy 400 hoist so here we go. Plus if i wanna hang myself after all this be easy 5 Quote
420ponies Posted June 6 Posted June 6 (edited) Holy crap!! What is anchoring that cross bar? Might want to rethink that! But, it's outta there, that's what counts! Edited June 6 by 420ponies Added content 2 Quote
jbird72 Posted June 7 Author Posted June 7 3 hours ago, 420ponies said: Holy crap!! What is anchoring that cross bar? Might want to rethink that! But, it's outta there, that's what counts! 2.. 2 by 6. ..only 3 ft ish apart screwed in with 3 on each side framing screws.ill send yu pick. There same hold as lag bolt Put strut on top figured better than screwing to bottom. 1 Quote
jbird72 Posted June 7 Author Posted June 7 3 hours ago, 420ponies said: Holy crap!! What is anchoring that cross bar? Might want to rethink that! But, it's outta there, that's what counts! Actually puy new cross bars in for the winch 1 Quote
jbird72 Posted June 7 Author Posted June 7 26 minutes ago, jbird72 said: 2.. 2 by 6. ..only 3 ft ish apart screwed in with 3 on each side framing screws.ill send yu pick. There same hold as lag bolt Put strut on top figured better than screwing to bottom. 1 Quote
