NOS Z20 Posted June 7 Posted June 7 I am in the process of putting the 10-piece lower moldings on a project I am finishing. My problem is the clips don't seem to be correct, or the moldings are not made right. The moldings fall right off like there is no tension on them. Has anyone else run into this and if so, what was the fix? 1 Quote
willie Posted June 7 Posted June 7 Steve what pieces are you needing help with as i think some have different clips then others??? I know some will take the Avvco #8400. In other treads that has been discussed. Quote
jft69z Posted June 7 Posted June 7 I spoke with Steve, he was more concerned with the door clips being loose. We did discuss the Auveco 8400 clips for the lower rocker, and I sent pics. As a side note, here is the Syracuse Nationals hotel info we talked about as well Steve: 1 Quote
Scott S. Posted June 7 Posted June 7 7 hours ago, NOS Z20 said: I am in the process of putting the 10-piece lower moldings on a project I am finishing. My problem is the clips don't seem to be correct, or the moldings are not made right. The moldings fall right off like there is no tension on them. Has anyone else run into this and if so, what was the fix? Are they "new" reproduction moldings ??? I've read that they can be a little "loose" in the clips. Quote
