FL 72 Monte Posted July 31 Posted July 31 I saw somewhere here someone said that it would fit with little modifications so I wanted to try it, I didn’t like the look of the ones they have for the montes, I think not bad for 50 bucks what do you think? 5 Quote
MCfan Posted July 31 Posted July 31 Nice! I like it - does it mount to the bottom edge of the bumper? 1 Quote
Marks71 Posted July 31 Posted July 31 It works well. Are you using the braces on the ends and center? 1 Quote
FL 72 Monte Posted July 31 Author Posted July 31 2 hours ago, MCfan said: Nice! I like it - does it mount to the bottom edge of the bumper? Yes also can get with mounting kit comes with three braces ends and middle 1 Quote
FL 72 Monte Posted July 31 Author Posted July 31 1 hour ago, Marks71 said: It works well. Are you using the braces on the ends and center? I will haven’t put them on yet wanted to make sure I liked it first thanks 1 Quote
MC-71 Posted July 31 Posted July 31 5 hours ago, FL 72 Monte said: I saw somewhere here someone said that it would fit with little modifications so I wanted to try it, I didn’t like the look of the ones they have for the montes, I think not bad for 50 bucks what do you think? Quote
MC-71 Posted July 31 Posted July 31 I posted about using the 69 Camaro Spoiler. Glad you tried it. Can’t beat the price. Looks good. 1 Quote
FL 72 Monte Posted July 31 Author Posted July 31 2 hours ago, MC-71 said: I posted about using the 69 Camaro Spoiler. Glad you tried it. Can’t beat the price. Looks good. Thanks for sharing,in my opinion the front needed something and the ones they have for the car just look too big or too much angle forward thanks again,any one else have one let’s see it!! 1 Quote
Robnhood Posted July 31 Posted July 31 9 hours ago, FL 72 Monte said: I saw somewhere here someone said that it would fit with little modifications so I wanted to try it, I didn’t like the look of the ones they have for the montes, I think not bad for 50 bucks what do you think? linkage for the part? 1 Quote
DragCat Posted July 31 Posted July 31 Just my .02, if I were to do it I'd rather have something that fits the whole front end. Big price difference tho 🤣 5 Quote
FL 72 Monte Posted July 31 Author Posted July 31 1 hour ago, Robnhood said: linkage for the part? Got from SS396 2 Quote
Scott S. Posted July 31 Posted July 31 I like them.... But I "improvised" mine. It's been painted black since the first photo was taken. 3 Quote
Rob Peters Posted July 31 Posted July 31 Spoilers aren't really my thing but I can appreciate other people's desires. rob 2 Quote
FL 72 Monte Posted August 1 Author Posted August 1 13 hours ago, DragCat said: Just my .02, if I were to do it I'd rather have something that fits the whole front end. Big price difference tho 🤣 Yes that looks good but the only one I could find for the monte I don’t like the look 3 Quote
FL 72 Monte Posted August 1 Author Posted August 1 3 hours ago, Scott S. said: I like them.... But I "improvised" mine. It's been painted black since the first photo was taken. I like the black better is that one of Randy’s? 2 Quote
Scott S. Posted August 1 Posted August 1 It's the same part, just painted.... And, no, it's not one of Randy's. Although, it is a genuine G.M. part. It's the tail spoiler from a 2004 Monte Carlo. I told you I was good at re purposing stuff... 2 Quote
FL 72 Monte Posted August 1 Author Posted August 1 14 minutes ago, Scott S. said: It's the same part, just painted.... And, no, it's not one of Randy's. Although, it is a genuine G.M. part. It's the tail spoiler from a 2004 Monte Carlo. I told you I was good at re purposing stuff... That’s great thanks 2 Quote
MC-71 Posted August 3 Posted August 3 On 7/30/2025 at 9:05 PM, FL 72 Monte said: I saw somewhere here someone said that it would fit with little modifications so I wanted to try it, I didn’t like the look of the ones they have for the montes, I think not bad for 50 bucks what do you think? Quote
MC-71 Posted August 3 Posted August 3 Buy two. Cut the first one in the middle. Take the pc from the second one and add it to the middle. Get creative and do some body work on it and paint it. That will stretch out to make it longer.🤔 1 Quote
kpcsgasp Posted August 3 Posted August 3 Ordered this one on line. bolts to the hood latch bracket and two small holes on the frame. 5 Quote
Scott S. Posted August 4 Posted August 4 These ones actually route air up and through the radiator.... Adds to cooling my transmission cooler. 1 Quote
bob 71 Posted August 7 Posted August 7 scott i am interested in the spoiler you say pushes air up to radiator. any info would be appreciated. thank you Quote
Scott S. Posted August 7 Posted August 7 Hey Bob, I used the tail fin from a 2004 Monte Carlo and basically rolled it 180 degrees. I made a few 3/4"x 3" "L" brackets bent at 1"-2", then drilled holes in the 1" section for the studs on the fin. Once I centered it, I drilled holes into the tray below the radiator where the bracket lined up to. ( be sure to use blocking so that you don't drill into the rad. ) Then aligned the brackets to match the holes. Once it's mounted, it sits flush with the rad support with enough rake to force air up. I'll try and get some pics for you. Scott. 1 Quote
FL 72 Monte Posted August 8 Author Posted August 8 On 8/6/2025 at 10:22 PM, bob 71 said: scott i am interested in the spoiler you say pushes air up to radiator. any info would be appreciated. thank you Here’s one if you’re interested 1 Quote
