So I have learned that a Chevelle rear seat will not fit a 1971 Monte Carlo, yes I'm using my Chevelle as a donor vehicle. I have striped the seats, however there are fine metal rods through the burlap. They are toast!! How important are they, and can they be replaced? Thanx1000005559.thumb.jpg.a1c26b468d573e33e072854b338856ee.jpg1000005560.thumb.jpg.23f2e74725ffb1440999bdefae2228a3.jpg1000005562.thumb.jpg.5bc201567f1f646da34772c611d6a83b.jpg1000005564.thumb.jpg.302941795397dc2c6c4bd6c21e9aea80.jpg1000005566.thumb.jpg.54a9fe25456c99088a8d2e15a5aa1d3d.jpg
I don't remember mine having them in there. I did put new burlap and also used canvas on them too. I did put extra springs in drivers side front seat too, that helped a lot. I did think the Chevelle frames were the same though. Hog rings are a real pain get a good set of hog ring plyers not a cheep set.
A 68 Chevelle doesn’t have full arm rests that extend to the floor in the back if I remember correctly so the rear seat is wider.
19 hours ago, Scott S. said:
Is it a 4 door Chevelle ?
It is a 2 door.
The interiors I have came from a 68 & 69, back in the day when they were a dime a dozen. I will measure the second one to see if it is different. The seat I measured was wider.
On 8/21/2025 at 9:23 AM, Bigfeetny said:
It is a 2 door.
1970-72 Chevelle seats fit. I believe the 68-69 had a different rear seat and armrest.
That is what I learned. Back to redoing the original seats.
