My car has a small block and a th350. If I try to put in a factory 4 speed manual tranny, will the driveshaft work or do I have to get it lengthend/shortend?
I believe it depends on the turbo 350 weather it has a 6 inch or 9 inch tailshaft to match up with the 4spd one then the driveshaft should be the same...Plus you will have to put on a manual flywheel too for the clutch assembly to join too.
Yeah, thats right Sam the crossmember is different too... I also forgot the steering columb too is different...
Speedometer is different, not needing the PRND12.
If your doing all that work, go with something with an overdrive.
I was just wondering, my car needs its complete restoration first before I would attempt that. I was just wondering, since the car is apart it is easier to make changes now instead of later. Unless I win money I'll probably keep the th350 and continue with the resto as planned.
What's involved in install a 4 spd in a Monte? Doesn't someone make a kit for swapping from auto to manual.
Think about using an overdrive automatic then.
Not really. But 5 and 6 speed kits are available
www.keislerauto.com
I went the overdrive route, but not what I expected. I may research the Vendors Gear Drive unit some have talked about on the site. I wanted the low gears of a TH400 and the 700R4 just didn't give me what I wanted. I still want it to drive on the road, and still have the gears to run the track.
..... I wanted the low gears of a TH400 and the 700R4 just didn't give me what I wanted. I still want it to drive on the road, and still have the gears to run the track.
I may be misunderstanding you . The TH400 has a higher first gear ratio than a TH350 . The 700R4 has the lowest first .
