I would guess around 50 lbs
If you go with a pin on, it should be more than that considering the weight of the hinges, and the latch assembly that bolts in the radiator support.
Just the hood weights 80 lbs.
GlassTek said the Monte pin on weights 14 lbs, I think they're pretty close... smile But I've never weighed my fiberglass hood.
I think I remember weighting a 71 Monte steel hood, 200lbs, in 1995. Key word in last sentence is think. Ed
As far as weight savings it depends on the hood style...pin on type, street duty, how big of a scoop if any at all, etc...
Mine with a 4" cowl and finished underside has to wegh 45-50 lbs. I can't believe I did not weigh it before I put it on... crazy
You got the "think" part right... lol It weighs 80lbs. like Jared said... wink
I think I am Hercules, installed a steel hood a few times all by myself....grin
hey Andreas you aint alone..Ive removed adn reinstalled the stock hood on my monte quite a few times...not fun!!!
I have done it too! Gotta use your head, literally!
I just had to pick up my stock hood the other day and I sure thought that was more than 80 lbs. All I know it was a hand full.
Funny to read how other people put their "steel" hood on by "themselves"...I also did it and don't think I'll try it ever again. I put a bunch of cloth towels on the windshield in case the hood slid into it and the whole time thinking I should stop and abort this mission before I cause some damage...I gotta admit though taking it off by yourself is not as bad.
The original hood on my '72 was 86 lbs, the fiberglass cowl was 13 lbs.
