youngmonte71 Posted October 13, 2010 Posted October 13, 2010 In a 71 monte with a 350 turbofire engine 350 turbo tranny and a 12bolt rear end what is the gear ratio in the rear end? Quote
Canuck Posted October 13, 2010 Posted October 13, 2010 A 273 rear end was very common for A 350/350 Car. Quote
Chevyss Posted October 13, 2010 Posted October 13, 2010 That's what was in my Monte when I first got it. Quote
ThirdMC Posted October 13, 2010 Posted October 13, 2010 Look under the Tech Info section. If nothing has been changed it will give you the codes to decipher your ratio. It's also on the build sheet if you're able to find it. Â Mine is also 2:73. Quote
Heff Posted October 14, 2010 Posted October 14, 2010 Unless its a 4 speed or powerglide transmission, or an ss car it would be a 2.73, although it could be ordered as a posi Quote
Mike 57 Posted October 14, 2010 Posted October 14, 2010 Mine was originally a 402 th400 with a 2.73 open Quote
Mike 57 Posted October 14, 2010 Posted October 14, 2010 Needless to say mine is not a 2.73 open anymore either! Quote
monte70car Posted October 14, 2010 Posted October 14, 2010 Mine still sports the org. 2.73 gears but with a power trax unit gets about 16mpg with a big block and a 700r4. Quote
