Luke Posted October 25, 2010 Posted October 25, 2010 Where can I find out what gearing the Monte has? I looked in the book but it did bot say it has a 12 bolt and not sure if it limited slip or not if that matters. Quote
Mike 57 Posted October 25, 2010 Posted October 25, 2010 Check here for info to help you determine what you have Rear axle decoding Quote
Luke Posted October 25, 2010 Author Posted October 25, 2010 Thanks very interesting information. Quote
Blake350 Posted November 9, 2010 Posted November 9, 2010 Luke if you have a tach there is a simple formula based on RPM,MPH ,and tire size-just if you want to confirm your findings... Quote
kc8oye Posted November 9, 2010 Posted November 9, 2010 blake: assuming that his speedo is correct Quote
Blake350 Posted November 17, 2010 Posted November 17, 2010 Something else came up after i posted-would the formula have to be adjusted depending on tranny used,as I would assume there are differences between the various automatics,not to mention 3 and 4 speeds?? Quote
kc8oye Posted November 17, 2010 Posted November 17, 2010 blake.. no.. all GM automatic transmissions have a 1:1 third gear the 350, 400, 200-4r and the 700r4 (i think there are a few 400's that have an odd set of gears) 4th gear in a 700r4 is .73:1 not sure about the 200-4r off hand. Quote
