BuffaloBillPatri Posted November 13, 2010 Posted November 13, 2010 355, New old stock B&M TH400, & B&M Hole-Shot 3000 T/C Shakes when bolted up to flexplate, don't when un-bolted. What can cause this? BBP Quote
BuffaloBillPatri Posted November 13, 2010 Author Posted November 13, 2010 Flexplate & all bolts are new, not cracked or loose. I had trouble getting the T/C snout to slip into the crank evenly, could be that it's still causing the shake. I'm going to re-clock the T/C 120* & retry it. I hope the TH400 front pump is not bad, as it's well beyond the B&M warranty. The B&M Holeshot 3000 has a lifetime warranty, but would they honor it after 15 years? I drove the car about 5 miles & T/C & transmission seemed to operate properly, except for the shake. BBP Quote
Heckeng Posted November 13, 2010 Posted November 13, 2010 I'm not getting what you are saying Bill. How can you tell if the converter is shaking? Quote
BuffaloBillPatri Posted November 13, 2010 Author Posted November 13, 2010 I just re-clocked it, no help. I lubed up the snout with WD40, seems to move easy into crank. Car is up on stands & I can rev motor. With it bolted up it shakes worst as I increase RPM I can feel it in floorboards & seat. It is either the T/C or the TH400 With it unbolted it's smooth. BBP Quote
Mike 57 Posted November 13, 2010 Posted November 13, 2010 Bill how long have you had the trans and converter? How many miles are on them? It sounds like you have had them for quite a while but never ran them. If I recall correctly there is not a lot moving in the trans while in park and the pump is not really that big in diameter or weigh that much to cause a vibration. I would point to the converter as the cause. Quote
kc8oye Posted November 13, 2010 Posted November 13, 2010 bill: are you doing the bolts up tight one at a time? you need to do them up evenly.. spin them in snug with your fingers.. spin the crank over a couple of times, then snug them down.. I had the same problem with my TH350 once when I didn't do this.. and I wiped out my front pump from it. Quote
BuffaloBillPatri Posted November 13, 2010 Author Posted November 13, 2010 I've had the parts about 15 years. This Summer I finally got it started. About 5 miles driven so far. This last attempt I tried easing the nuts a bit at a time, I will take it slower next try. Tomorrow I will clock it another 120* and balance the 3 bolt/nut/lockwasher units together on my digital grain scale. BBP Quote
Heckeng Posted November 13, 2010 Posted November 13, 2010 Is the trans acting right? Do you have engine braking? Quote
BuffaloBillPatri Posted November 13, 2010 Author Posted November 13, 2010 Yes, "I drove the car about 5 miles & T/C & transmission seemed to operate properly, except for the shake." I'm getting fed-up with this Damn B&M T/C, am looking at Coan 10" Pro Street Comp $350 BBP Quote
BowtieThunder Posted November 14, 2010 Posted November 14, 2010 sounds as if converter is out of balance can you tell if there was a weight on the converter that may have come off.NOt sure if there is a tranny shop or machine shop in your area that could rebalnce the converter,That might be all it needs Quote
BuffaloBillPatri Posted November 14, 2010 Author Posted November 14, 2010 I think it's good now, much less vibration at least. Maybe normal now. I checked bolt/nut/lock washer balance, all 3 sets were 448 grains. I clocked it another 120* & slowly tightened the nuts as I rotated the crank, about 5 revolutions. Thanks a bunch Tim (Kc8oye) BBP Quote
kc8oye Posted November 14, 2010 Posted November 14, 2010 np bill.. if you get that tc even a hair off center... i did my torque converter one one bolt completely tight at a time, and it warped the heck outta the flex plate.. and hammered the tc back and forth until it took my front pump out. (this is what finally pushed me into the 700r4 swap) Quote
Heckeng Posted November 14, 2010 Posted November 14, 2010 One other thing that you may have solved by turning it, I have had TCs with and without drain plugs, and on one of them it stuck out the back of the TC so that it would only bolt up flush in one position. I also bent my flywheel and had it off ballance like this. Any chance of that? Hopefully you have it all under control now regardless! Quote
BuffaloBillPatri Posted November 14, 2010 Author Posted November 14, 2010 Time will tell if it's going to hold up? I won't drive it in the cold weather though, summer tires etc. I haven't had it above 4000RPM yet. I wonder how much this 10" B&M Holeshot 3000 will slip at 3250RPM, my calculated at 75mph? I have read numbers around 10% The Coan 10" 20310 is suppose to be around 6% I run the ATF through an engine type remote oil filter, then the radiator, then a cooler that's in front of the passenger side of the main radiator. Thanks again, BBP Quote
