Maybe someone can answer this......
If I take a stock 118cc big block head and mill it .025, what does that make the combustion chamber now?
Thanks,
Steve
My 119cc merlin heads gave an average figure of 1cc for every .007 removed.
I'd guess you'd have around 114-115cc.
As Sam said about the intake been there done that got lucky and the local parts store paid to have my intake shaved the thickness of the intake gasket.
Those are my current cast heads and yes the intake had to be milled as well.
I'm in the middle of getting myself together for my aluminum head swap and just wanted to see if the new aluminum heads that are 110cc's was going to change my compression ratio.
Turns out the stock 71 big block heads are 113cc's. Which would mean they are also 110cc now.
Oh..and eventually I'm going to try to sell my current manifold. It's an Edelbrock Performer RPM (not an air gap)that has been milled .030.
Steve,
i'm sure you already know, in case you didn't or forgot, you will need longer head bolts/ stud. and longer pushrods.
thanh
Thanh,
Thanks...Already ordered and delivered and waiting to be installed.
Mike57 has been a big help in letting me know what I'm going to need....And Crazy Dave has also been giving me pointers...I love this group!!!
Its a Big Block conspiracy I tell ya...They're all scheming against me. lolol.
the dark side is waiting for you my son.... devil
it's hard to argue with the results of a big block rofl
al.. We can always set you up with a twin turbo small block to spank those big block's.. ask Eli what his monte runs in the 1/4 mile smile
11's letting of at the 1/8th mile...
