Getting the engine ready to go back in.
Bottom end forged stroker, eagle .250 long rods, ARP L19 bolts
SRP Pistons
AFR Heads, Vic Jr intake
Do you think you will break into the 10's with it now?
That engine always looks so squeaky clean it's hard to believe you actually drive it... cool
Looks great Mike!!Like the valve train pic. Get it dialed in and low 10's for sure!! cool
David
Very nice!
Mike, that looks awesome. Looking forward to seeing some numbers.
ditto - Dave
Wow nice looking engine! Can't wait to hear it running and to see the new numbers cool
Are those valve cover studs? They almost look like push rods...
I tried using studs for my valve covers and couldn't remove the covers after the engine was installed. I needed to have a bit of sideways motion to get the covers to clear the brake booster, etc.
It's not a problem if you remove the studs every time you pull the covers, but that kinda takes the convenience right out of it.
Wish they made a set of clear valve covers. That valvetrain train is purdy!
Can't wait to here about the new time slips and looking forward to hearing it at the Eastern Meet.
You know Al will be jealous, he loves horsepower!!
Dan
Holy Ground Pounding Big Block!!
That thing looks serious..........
Mike has hydroboost brakes..... wink
Thanks for the kind words guys!
Dave is right, I run a hydraboost so the covers come off pretty easy. I run a solid roller and I like to check the valves every so often they usually stay in adjustment, but I like to check to keep an eye on the rollers. I have run the same cover gaskets for four years
