dbreese Posted December 4, 2006 Posted December 4, 2006 Looking to replace my old 26x10.5 ET Streets. I am going to mount them on 15x8 4.5 bs Weld Draglites. Will these fit without any mods to the well opening? TIA David
502ci Posted December 4, 2006 Posted December 4, 2006 On the 28x11.5 MT/ET Streets they have a section width of 11.10 inches on a 8" inch rim. This is the measurement you will be concerned about. Now on the Weld Draglite having 4.5" of backspacing it will put you close to the outer wheel lip. 5" of backspacing is ideal but the 4.5" may work, for sure it will clear the frame but as I said it will bring it close to the lip, is trimming the lip an option? Because that will make it fit for sure...hopefully someone will chime in and verify a fit with no modifications... Also when I`m figuring if a wheel will fit or not I`m always referring to the sidewall clearing the lip and frame, even if the suspension was fully compressed. I never say it will fit if you have to lift the rear to keep it from hitting the tire...
dbreese Posted December 4, 2006 Author Posted December 4, 2006 I don't mind triming the lip as long as I can keep the wheel molding. I know with the 26x10.5 I have about 1/2" gap on the lip. The way my exhaust runs I have about 1/2" gap between the pipe and the tire. Course that would be a simple mod if I needed more clearance. Thanks David
502ci Posted December 4, 2006 Posted December 4, 2006 I did not know these were the same wheels you had on before with the smaller tire. Then the answer is easy...if you had a 1/2" of clearance to the lip then with this new tire you will have just over an 1/8 of an inch of clearance... Here`s how I figured it out...your old tire has a 10.5" of sidewall on that 8" rim, the new has 11.1, a difference of .6, divide this by 2 getting .3 You had a .5" clearance now subtract .3" leaving .2" of clearance...trimming will be necessary...
502ci Posted December 4, 2006 Posted December 4, 2006 Here`s a view of my lip that I trimmed...I took off quite a bit and there is plenty left. I have a 1/2" of clearance on mine but my tire and wheel combo are completely different than yours. I think you will have to trim alot less than I did.
Guest Posted December 4, 2006 Posted December 4, 2006 You will definatley have to trim the lip, and it's still going to be close, keep in mind when your cornering you could get some rub, you will have to trim the lip all off (it's a water catcher anyway) to make sure you don't rub the tires on a hard turn. 2 cents
dbreese Posted December 5, 2006 Author Posted December 5, 2006 Thanks guys. Guess I will have to do some trimming. Bill, what size D/R's do you have? They look rather big . What is the best way to trim the lip? Would a grinder/cutoff wheel work? David
Guest Posted December 5, 2006 Posted December 5, 2006 grinder/cutoff wheel work? Yes it will but be careful not to get to much heat in the qtr panal, do a little at a time.
Sam (Bones) Posted December 5, 2006 Posted December 5, 2006 I've got 15x9's on mine with 5.5" of back-space, 10.5x28 slicks
502ci Posted December 5, 2006 Posted December 5, 2006 I used a air grinder and took off a little at a time which meant putting the wheel on, lowering it, and taking it off again quite a few times. I also applied por-15 to seal the bare metal forever. My wheels are 15x8 with 5" of backspacing with 325-50`s with a 1/2" of lip clearance (has never rubbed even with the car sitting low). 1/4" to 3/8" clearance on the frame that has rubbed a little on hard turns but does no harm.
AL M Posted December 15, 2006 Posted December 15, 2006 hey guys how about a 275/50/15 on a 15x8 rally???
Sam (Bones) Posted December 15, 2006 Posted December 15, 2006 I think that is a 26" diameter, how tall of a tire do you want,still agree with Bill, the 5" backspacing will be ideal, it will be close on the out side
KLASSIK1 Posted December 15, 2006 Posted December 15, 2006 you know Sam what i like about you , well there are a lot of reasons i like you to many to list , but whenever i have a question you are one of the first i turn to , been there done it kind of guy Leo
