Have been reading up on Q-jets & have a question, why is there a different part # for automatics vs manual tranny?
I have a 7041208 DN. The last number (8) denotes auto....
This may help:
Pre-76
7028219
DG 1938
70 - Prefix code. "70" will appear on all late '60's Rochester Carburetors.
2 - Decade produced.
2 - 1960's
3 - 1060's with A.I.R.
4 - 1970-1975
8 - Year produced. 8 = 1968
2 - Model
0 - Monojet (1 bbl) Federal standards
1 - Two jet (2 bbl) Federal standards
2 - Quadrajet (4 bbl) Federal standards
3 - Monojet (1 bbl) California standards
4 - Two jet (2 bbl) California standards
5 - Quadrajet (4 bbl) California standards
6 - VariJet (2 bbl) Fed
1 - Division.
0, 1, and 2 all indicate Chevrolet.
4 - Buick
5 - Olds
6,7 - Pontiac
9 - Transmission
Even numbers - Automatic Transmission
Odd numbers - Manual Transmission
DG - Customer code.
1938 - Date Code
193 - 193 rd Day of the year
8 - Year
MY CARB
7041202
DG 1938
2 - 1960's
4 - 1970-1975
1 - Year produced. 1 = 1971
2 - Model
1 - Division.
4 - Buick
5 - Olds
6,7 - Pontiac
9 - Transmission “2 = Automatic”
DG - Customer code.
0681 - Date Code
068 - 68 th. Day of the year (March 9th)
1 – Year (1971)
THX, I understand that...but whats different between the auto/manual style carb?
the throttle arm would be different, no need for kickdown linkage on a manual trans.
I'm not sure that is entirely correct because the TH-400 has an electric kickdown switch mounted on the accelerator pedal bracket. My guess would be the quantity of vacuum ports because a manual trans doesn't have a modulator. Just a guess.
The transmission modulator hooks up to the intake manifold on an automatic transmission.
so, what is the correct answer?
I tried doing some research. Closest answer I could find said that manual trans carbs have a vacuum pull off for idle when you take your foot off the gas. Sort of keeps the rpm's up a little. Seems that most rebuilders leave them off. Seems like a MT carb will work fine in an Automatic car. I swapped my Q-Jet out in the early 80's for a Carter. Should have kept the Q-Jet but who knew?
The difference is at the rear of the base it has no threaded hole for vac fitting for brake booster
Couldn't you get power brakes on a 4 speed car?
Bruce
In the future, I'm planning on pulling the TH350 & installing a manual (possibly a Keisler 5-speed)so that's why I asked the question.........bottom line is that I will need to close a vaccuum port on carb?
My 7040202 carb has no port on the back of the base, I have a hard steel line coming off the vacuum tee on the intake manifold, then a rubber hose going to the booster.
