Do big block 4 brl run a differant throttle cable then small block 2 brl ? If so , does anyone know where I could buy a new BB 4 Brl throttle cable ?
Im also having issues with my turbo 350 shift down cable being to short
GM parts direct list three on for sbc 2 barrel one for sbc 4 barrel and one for a big block. Now if you can use them on other applications not sure. Here is the link any Chevrolet dealer should be able to get them.
The throttle cables are different for a big block and small block. If you are running a holley carb you will need a cable for a holley q-jet cable is the same for all big blocks
Yea the HIPO cable is the the Holley, with the Edlebrock 750 you should be able to get away with using the throttle cable for a Q-jet since the Edlebrock kinda looks like a Q-jet or you could dress it up with a stainless braided cable.
I just went to Autozone and got one of the universal braided kits that are cut to fit and it worked fine. I have Edelbrock fuel injection on my big block...
