It seems with the inch carb spacer and Edelbrock RPM perfomer intake with a Holly avenger I am tight with a stock hood. Not sure exactly yet but does anyone have suggestions for a good recessed air cleaner unit
Scott you can go with a drop base air cleaner or get the specular air cleaner kit which is just a carb. hat and plumbing to make your own system. I take it you have the space because the intake is a spore bore? or are you after a little more power?
Thanks, definitely seem to have some options. I am at 6k altitude in NM. I need as much air available as I can get. I hope those recessed bases clear my throttle cable etc. I just want to do this once hopefully. I am kinda leaning towards the drop based kN filter unit. Maybe remove insulation and get the filter top version. The corvette unit with a recessed base and dual snorkel is great but alot more money it would seem.
