71monteme Posted March 4, 2006 Posted March 4, 2006 hi guys. what is involved in instaling these units? do you have to buy new axles to do this or can you use what you have? i know i will have to take the axles out of the housing. how are the bearing stay on the axle? any one done this please feed me some info. thanks. thanh
Sam (Bones) Posted March 4, 2006 Posted March 4, 2006 they make kits for this w/ new axles, after you remove your axles you will have to remove the backing plates, remove the seal & bearing, cut off the end of the axle, reinstall backing plates, slide the new axle in w/the bearing assem installed on the axle, the new axle bearing assem bolts to the axle using the backing plate bolts (new ones), the new bearing assem is what holds the axle in, I think mine was from Moesure Sam
71monteme Posted March 5, 2006 Author Posted March 5, 2006 sam. do you drive your on the street? did you do the work yourself? i read that they leak real bad if driven on the street. thanks for the info. thanh
Sam (Bones) Posted March 5, 2006 Posted March 5, 2006 thanh, yes I drive it about 1500 miles a year, no prob so far, and I did it my self, I'm an ex truck mech. not to hard, when you seal it just remember, CLEAN good to go!!! what do you run now??? Sam
71monteme Posted March 11, 2006 Author Posted March 11, 2006 sam thanks for the info. 11.20 so far . i'm trying to get into the 10's this year so i'm looking at the areas where the car is weak. i wanted to start with the rear end as i think it is the weakest link right now. also the safety issue. don't want a wheel/axle assembly leaving the car at high speed. thanh
Sam (Bones) Posted March 11, 2006 Posted March 11, 2006 thanh, I've run a 11.59 best lookin for more, have a few ideas Sam
71monteme Posted March 11, 2006 Author Posted March 11, 2006 sam i'm lighten up the front end with fiberglass fenders, a shot of 100hp nitrous. and i hope to be in the 10's.
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 I just want 11.0's, gonna change the engine some, no bottle, all throttle, I'm 3650#'s w/o me Sam
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 that would be ok, I just don't want to get to crazy Sam
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 thanh, Bill have you up-graded your rear suspension at all??? Sam
502ci Posted March 12, 2006 Posted March 12, 2006 Sam... I`ve installed QA1 rear 12-way adjustable shocks, Hotchkis rear lowering springs, adjustable rear spring spacer (sits under the spring on the perch), adjusts from 0 to 4", it can be used to preload right rear tire or lift both sides, adjusts in seconds with a socket set, Hotchkis rear sway bar, edelbrock double adjustable rear upper control arms, edelbrock boxed rear lower control arms, edelbrock tubular rear braces (for strength and to accurately locate rear suspension). The rear end is from a 70 chevelle, with a 4.11 posi, added moser c-clip axles with 1/2" wheel studs.
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 Bill, I've never heard of those adjustable spacers, where did you get them??? I want a set Sam
502ci Posted March 12, 2006 Posted March 12, 2006 Heres the link... http://www.budzter.com These spacers are nice and heavy duty.
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 thanks Bill, those are great, gotta have a set Sam
71monteme Posted March 12, 2006 Author Posted March 12, 2006 bill, those adjuster looks great, it does kinda the same thing as the air bags do. sam. the only thing i did to the rear suspension is install a set of South Side Machine lift bars, heavy duty coil springs. everything else is stock. will be installing airbag in the right rear coil spring this year. thanh.
Sam (Bones) Posted March 12, 2006 Posted March 12, 2006 I put air bags in mine, hotchkiss lower control arms, and no-hop adapters, need to do the uppers and braces Sam
mc71454 Posted April 25, 2006 Posted April 25, 2006 Nice Ride Sam... Hey Thanh, what is your race schedule this year? We need to meet up at LVD this year...
mc71454 Posted April 25, 2006 Posted April 25, 2006 Thanh, I use the Mark Williams Kit. Installed it about 5 years ago. Very easy install and no leaks...
71monteme Posted April 26, 2006 Author Posted April 26, 2006 hey tom. good to see you posting here. do you have to use their axles with their kit? i know strange said their kits are only for their axles. it looks like we will be at LVR on the 6th of may if the weather is good if not then the first saturday that the weather is good. hope to meet up with you. thanks. thanh.
mc71454 Posted April 26, 2006 Posted April 26, 2006 Hey there.. Yes, you need to use their axles... I will be there May 3rd for a T&T and then I have a track rental on Friday May 5. Swap meet on Saturday May 6, and another one on May 7...What a busy week next week... Are you going to make it up to Hemmings Musclepalooza on May 27 ??? I will surely be there.. Tom
71monteme Posted April 26, 2006 Author Posted April 26, 2006 hey tom. WOW you are a busy man. where are the swap meets? yes i was planning on attending the musclepalooza. so i will see you there. we will be test and tuning the camaro for the summer national in june at englishtown, nj. the monte will be making runs to see how much more work i have to do to get to my goal. not legal yet( no roll cage) thanh
mc71454 Posted April 26, 2006 Posted April 26, 2006 Sounds Like a Plan.. Swapmeets - Rhinebeck NY, Dutchess County Fairgrounds - May 6. Bristol CT - May 7 Put the headers back on last night. I have some new fully CNC'd AFR Heads and was worried the headers were going to hit the frame..Nope, they fit better than they did with the Canfield heads
71monteme Posted April 26, 2006 Author Posted April 26, 2006 tom. bristol, ct is about 10 minutes from my house. i might be going there also. give me a call when you get there, maybe i'll see you there before the palooza. 860-514-5325. thanh.
mc71454 Posted April 26, 2006 Posted April 26, 2006 I will ! Is it a good swap meet, If I do not do well at Rhinebeck I will absloutely be there. If Rhinebeck goes well I will skip it..either way I will let you know.. Thanks
