There is a male inlet right dead center from of my Edelbroch 750 carb. There is no hose going to it. It's sucking in air very badly. Should this hose be capped ? Its very loud also and if You put your finger up to it it will suck Your finger right up to it.
I don't have an Edelbrock but you shouldn't have an open vacuum port just sucking in ambient air. Are you sure there are no hoses in the area that should be connected to it. If not, i'd cap it pronto.
It could be for the power brakes, but if not using it for that, plug it with a cap.
A 3/8 vacuum cap should fix you right up.
What was on there before?
Could it be for PCV valve? Most of the time power brake fitting is in the rear somewhere.
Either way, it shouldn't be open and sucking air. It should have a hose going to something or be capped off. Maybe it was capped off and a backfire blew the cap off?
in between the adjustment screws? Isn't that where you hook-up the PCV hose? Most are t-tapped to valve cover,,& so on. Damn it you're quick Mark!! lol
My OEM 71 Quadrajet has a PCV valve hose hooked to a vacuum fitting like you are describing. Here is a picture.
Bruce
1971 Quadrajet on a 350
Bruce
Hey Bruce could you take a picture of the right side (vacuum) I think I maybe missing some things? but don't have a Quad from the era to check or see what it maybe or not.
Thanks
Scott
Here is the entire album, hope it helps. 70 may be different than 71.
71 350 Quadrajet
The tube on the front of the Eldebrock is for the PCV valve. I just installed a 1406 Eldebrock on my 72 and that is what the instructions said it was for. I had to put a spacer under the carb for the power brake vacuum control. The vacuum advance is on the left side of the PCV valve connection. I had it on the right side and it now runs better than it did. This is while standing in front of the car looking at the carb.
The tube on the front of the Eldebrock is for the PVC valve. I just installed a 1406 Eldebrock on my 72 and that is what the instructions said it was for. I had to put a spacer under the carb for the power brake vacuum control. The vacuum advance is on the left side of the PVC valve connection. I ha it on the right side and it now runs better than it did. This is while standing in front of the car looking at the carb.
I'm sure you meant "PCV" wink
Steve,
Yes, cruise control. I added it about 24 years ago.
Bruce
Yep Rod ya dun caught me LOL and the miscue is fixededed.
Just keeping you on your toes! lol
