Hello everyone, How difficult is it to change all the body bushings? Can I do them one at a time, or do I need to lift car off of frame to replace?
no you can not do them 1 at a time..you will have to take them all aloose to even remove one..I belive you can do one side at a time but from what Ive heard you have to lift the body off the frame a lil bit to get em all out..Im sure others will chime in..i am contemplating this also!!!
Some of the mounts can be a bear to remove depending on the history of your car. Also, you can't do one at a time but you can do one side at a time, that is what I did.
If you want, see the following album for more info on the steps I used <Linky>. Others will likely have their own ways to get this done.
Good luck
  • 3 weeks later...
