jacob Posted February 17, 2012 Posted February 17, 2012 I wanted to see if theres another way to pull out dents I have been using a dent puller with screws and after pulling the dent out covering the hole with bondo. I have used a body hamer but I cant get to most of them which are higher up. I have used suction dent pullers that you squezz and pull... there not worth messing with. Quote
Chris Posted February 17, 2012 Posted February 17, 2012 Stud welder with a slide hammer attachment. No holes to fill after. Similar to this: http://www.eastwood.com/stud-welder-dent-pulling-system.html Quote
Sam (Bones) Posted February 17, 2012 Posted February 17, 2012 use duraglas over those holes first, then body filler Quote
RichG Posted February 17, 2012 Posted February 17, 2012 You need to weld the screw holes closed. If you just fill with bondo, it may eventually crack and fall out leaving a hole. The proper method is a quick blast with a mig welder and grind it smooth. No future worries. Quote
BURNOUT BOX Posted February 17, 2012 Posted February 17, 2012 its 99.00 at this place,I had my stud welder for 3 years now,best 99.00 i spent http://www.harborfreight.com/stud-welder-dent-repair-kit-98357.html Quote
jacob Posted February 17, 2012 Author Posted February 17, 2012 I like the stud welder Theres a harbor freight near hear so I will look for that. dose any one know any thing about welders I have not used one ansd wuld like to learn how to us one I know harbor freight has them Whats the cheapest they sell for and what kind to buy. Quote
BURNOUT BOX Posted February 17, 2012 Posted February 17, 2012 I like the stud welder Theres a harbor freight near hear so I will look for that. dose any one know any thing about welders I have not used one ansd wuld like to learn how to us one I know harbor freight has them Whats the cheapest they sell for and what kind to buy. http://www.harborfreight.com/110-amp-220-volt-flux-and-mig-welder-94164.html You can add gas,But practice on something, Quote
jacob Posted February 18, 2012 Author Posted February 18, 2012 I like that welder and I like the price even more has any one used a 110 amp welder like that? How well dose it work? I have read the reveiws some said they used it only 4 times and It died. Are there any tips I need know before welding? Quote
BURNOUT BOX Posted February 18, 2012 Posted February 18, 2012 I had my welder 3 years and still works. Quote
bigtankjones Posted February 18, 2012 Posted February 18, 2012 I have a Hobart 110V welder that I bought from Tractor Supply about 5yrs ago. You can use flux core or gas weld with it. One of my best tools in my garage. Cost anywhere from $450-$600 now. I think I payed $435 for mine. Quote
bigscaht Posted February 19, 2012 Posted February 19, 2012 my friend has that harbour freight welder..he likes it..has had it(the older version) for 4 years with no problems..besides the lack of heat settings...its good to learn on...give it a try. Quote
jacob Posted February 19, 2012 Author Posted February 19, 2012 I found one for 189.99 its a dual welder mig and tig I want to get it. I bought a 7 inch polisher from drill master has any one used it. Quote
bigtankjones Posted February 20, 2012 Posted February 20, 2012 I found one for 189.99 its a dual welder mig and tig I want to get it. I bought a 7 inch polisher from drill master has any one used it. Where did you find the dual welder? Quote
black07ss Posted March 1, 2012 Posted March 1, 2012 Not sure what every one here thinks, but my experience with Harbor Freight is they have cheap tools cheap. I buy some specialty tools there if I need to use it only a few times. I am not sure if I would buy a welder from there Quote
Leghome Posted March 1, 2012 Posted March 1, 2012 DITTO. Although I did buy and framing nailer there 10 yrs ago and it is still going strong. Granted it is not used every day but when used it is used hard and a lot. I do keep it oiled when using it though. Quote
monte70car Posted March 1, 2012 Posted March 1, 2012 Well I brought a stick/tig welded from them and in return had to get more power to the garage. Once the power was finished the stick side of the welded works good haven't tried the tig part yet. When we upgrade our air compressor they will probably get the money as everyone wants close to $500 for the compressor we have our eye on. Some of their tools do look cheap but the warrenty is the same as caftsman when a hand tool breaks. Quote
black07ss Posted March 2, 2012 Posted March 2, 2012 I got these butt weld clamps from Eastwood they worked great. A month or so after I got them I saw some at Harbor freight. I bought them because it was only $8 bucks. I compared them to the Eastwood ones and they are exactly the same!!! Plus twice as many!! Eastwood link http://www.eastwood.com/intergrip-panel-clamps-set-of-4.html Harbor Freight http://www.harborfreight.com/8-piece-butt-welding-clamps-44751.html Quote
Ian Posted March 2, 2012 Posted March 2, 2012 I have some 3/4" drive sockets from Harbor Freight and beat the heck out of them with my 1200 ft/lb Matco (IR) impact and they are holding up to daily use on trucks. I also have their 20 ton air powered bottle jack that I use just about everyday for lifting tractor and trailers with Quote
jacob Posted March 4, 2012 Author Posted March 4, 2012 I have a 30 gallon air compressor so airs not a problem and my dads freind is a electrition so powers not an issue. I need a stronger impact wrench and air wrench I need a welder but I wouldnt use full time. like for welding holes shut or puting in a peice of sheet metal. until i get my car Quote
bigtankjones Posted March 4, 2012 Posted March 4, 2012 Thats what I think about Harbor Feight to. I will use some of there tools for lite jobs. I wont buy any thing electrical from them cause it burns up to quick. Quote
jacob Posted March 4, 2012 Author Posted March 4, 2012 where do you buy welders and stuff then? Quote
alex's72fgmc Posted March 11, 2012 Posted March 11, 2012 a welding supply store, lowes, home depot, harbor freight, summit racing website. typically any place that sells or leases gas cylinders sells the welders Quote
jacob Posted March 13, 2012 Author Posted March 13, 2012 okay thank you I will buy one some day. Quote
