Toppless72 Posted March 21, 2012 Posted March 21, 2012 I’m sure this has been discussed before but, I am planning to convert my distributor this spring before the driving season. I want to keep my stock unit and install a Printronix or Accell trigger in it. What type do you guys use? I do not want to go with stock GM HEI because I want it to look stock. JC Quote
Ian Posted March 21, 2012 Posted March 21, 2012 Before I went to Fuel Injection and a Mallory Dist I ran the Petronix and it worked great. Quote
cny first gen 71 Posted March 21, 2012 Posted March 21, 2012 I have the pertronx in mine never had a days problem with it. Install was pretty simple dist has to be removed and a new power wire to the coil (the orig wire is a resistance wire) and the pertronx requires 12 volts to the coil when the key is on. Pertronx tech line is very good I called with a question and they were very helpfull. You may need a new coil also depending on the one you have on it. Good luck. Quote
abe72 Posted March 21, 2012 Posted March 21, 2012 I just installed the Accel (same reason as you) unit in mine a little over a month ago, so far so good. Install was pretty simple, as others have said the distributor has to come out. Quote
Mike 57 Posted March 21, 2012 Posted March 21, 2012 I have done Pertronics conversions on lots of tractors and a few cars never had an issue. I have other needs on the Monte and run a MSD. If I just cruised the Monte I would go with a Pertronics. Quote
Nygel Posted March 21, 2012 Posted March 21, 2012 I have been running a Pertronix setup in mine for 2 years with zero problems. Easy to install, even for the inexperienced. I ran one in my jeep for years before with zero issues also. Upgrade the coil and wires while you're at it. Nygel Quote
overdrive Posted March 28, 2012 Posted March 28, 2012 The Accel is about $20 less and I was able to get mine for our 71 at the local Autozone when I would've had to order the Pertronix. The Accel has worked great for 4 yrs now. Dan Quote
