I have a 402 engine,4 core radiator,2'' id at the water pump,1 3/4 at the radiator does any one know the gates hose # for that set up.I ordered one from the local parts store,not even close...Thanks,Mike
Molded Coolant Hose; 1 1/2" x 1 3/4" x 25 3/32" "20677" if it's a '70,'71 or '72. You're are off by 1/2" on both measurements? I guess the year would be important but I hardly think it matters on a 402cid Monte?
$(KGrHqJ,!jgE2vMb86gIBNvB-mVE+w~~0_35.JP
Get a Gates 22892 (lower radiator hose for 2003-2010 Dodge Ram trucks). It's a 1-3/4" x 2" with a 24-1/2" centerline length. Its contour is the closest I found to the 20677, which is what all Montes came with originally.
See this thread for additional information. Hope that helps.
Nick
