cudax Posted May 5, 2012 Posted May 5, 2012 Can anyone tell me why I used to be able to copy a web address or link and paste it on my threads here but now I can't? Also, I can't copy a picture/link from Photobucket to use as my signature. I was able to do that in the past but again am unable to so now. If anyone can assist me I would appreciate your help. Thanks, Mike Quote
Leghome Posted May 5, 2012 Posted May 5, 2012 Well you have to logged in and that you are because you are posting. Hmmm it is a mystery to be solved by someone more web savvy than I. Quote
Ian Posted May 5, 2012 Posted May 5, 2012 For your sig you need to use not Code: [image]picture[/image] as for the links if they do not end in .html or .htm the board does not convert them to links for you, so you need to use some address Hope this helps. Quote
7tonemonte Posted May 5, 2012 Posted May 5, 2012 Your close with the image thing, try copy and pasting this into your signature... and put that link in between the parenthisis [/img] Quote
Ian Posted May 5, 2012 Posted May 5, 2012 You had a extra space in the sig box, I fixed it. You need to resize the picture on photobucket, as it is a little too big for a sig picture Quote
