Paul Bell Posted March 10, 2013 Author Posted March 10, 2013 Looks good Sam! You should be cruising by tonight, right?
stangeba Posted March 11, 2013 Posted March 11, 2013 Just noticed your upper arms have the bushings attached by nuts where my 71 uses a 9/16" head bolt. Wonder if that is a 70 - 71 change? Bruce
Sam (Bones) Posted March 11, 2013 Posted March 11, 2013 no, it had the ones with the small bolts, those are MOOG replacements
stangeba Posted March 11, 2013 Posted March 11, 2013 OK, thanks! After I rebuilt the ft end on mine, those bolts came loose several times on me. Bruce
LostnFound Posted March 11, 2013 Posted March 11, 2013 Looking sweet Sam. You stayed awake for it today.
monte70car Posted March 11, 2013 Posted March 11, 2013 I got motor all finished and the inner fender back in Also got some work done on the trailer got the tool box mounted and and the wench in
cny first gen 71 Posted March 11, 2013 Posted March 11, 2013 Finished putting the plugs in today and took it out in the driveway for some air and to run a little. Finished sanding and polishing the windshield trim, it looks pretty darn good for fourty plus year old trim.
LostnFound Posted March 11, 2013 Posted March 11, 2013 Checked on mine in storage and everything is fine. I think I saw it smile at me.
CKZ03 Posted March 11, 2013 Posted March 11, 2013 Started getting my seats ready to get redone. Thought I found another build sheet inside the rear seat, turned out someone just threw garbage inside it As a constalation prize I found a canadian build sheet in one of the buckets purchased to replace my former power bench. Found it under drivers seat springs. Looks like they came out of a 350 2 barrel car. Its always cool finding stuff like this, even if it isnt for my car. Rear seat stripped down & sandblasted ready for fresh paint. Im eliminating any chance of anything smelling like mouse urine, cant stand that smell, & there were plenty of mice living in this car. Absolutely everything is getting blasted, cleaned, painted and/or replaced. Only things Im reusing from the seats is whats made of steel.
footballubet Posted March 11, 2013 Posted March 11, 2013 Started on my remote power door locks and trunk release install. Should have brought home my impact driver from work as the screws on the door latches won't turn. Got the wires run for the passenger side. Trimmed the trunk opening for the power latch and got that installed but didn't get the wire run for it. Started late in the day and not rushing it. I'll be doing a review of it after I finish the install. Stay tuned.
Leghome Posted March 11, 2013 Posted March 11, 2013 Scott got my car all tore apart and waiting to get my kit to do my install. Doors will be coming off late this week.
Andreas Posted March 11, 2013 Posted March 11, 2013 Nice day yesterday Started the installation of power side view mirrors (off a 97 Buick Lesabre)...
bigtankjones Posted March 11, 2013 Posted March 11, 2013 Yesterday. I did a little sanding of my firewall.Brushed some Eastwood Seam Sealer on my left front cowl panel. And sprayed a few coats of High Build Primer on the Firewall.
GREENSHOTRODS Posted March 12, 2013 Posted March 12, 2013 I was pretty happy with how the tank and pump turned out so I thought I would spend a little time on the differential cover. Now the axle housing and exhaust look bad haha...its always something !
Paul Bell Posted March 12, 2013 Author Posted March 12, 2013 Now that's what I'm talkin about!! Hey Kevin, shouldn't the sump be more at the rear or the tank towards the the bumper? If you're making some "real" power (and it looks like you are heeheehee) and you're hooking, I would suggest you get one of those cast covers that'll help support the bearing caps. They also have way convenient fill and drain plugs.
GREENSHOTRODS Posted March 12, 2013 Posted March 12, 2013 I talked to a bunch of different people about where the best place to put the sump and as usual the more people I asked the more confused I got. So done some mockup and I thought it looked the best on the bottom and I know I know when im out doing hole shots the gas will be running away from the sump. So I told myself " self just don't let the tank get to Low " LOL ! What I did screw up on is how hi I put the fittings in the sump ! Don't like how it looks but ill get over it I guess ! I looked at those Paul but as usual I went over budget on the fuel system so maybe next time
Paul Bell Posted March 12, 2013 Author Posted March 12, 2013 A friend recently shattered his 12 bolt in his blown '66 Impala (he says it's because I told him it would happen). He's ordered a D60. Years ago, I cleaned the teeth off my 9 inch. When I get this car apart again, I'm going with a D60.
CKZ03 Posted March 18, 2013 Posted March 18, 2013 Not much progress this weekend, indulged a bit for St Pattys day . Dropped my seats off at the upholstery shop this week. Currently trying to finish up my complete replacement wiring project. Had to temp install my dash in an effort to route & fit dash harness/bazillion wires. Disregard the mess, Im definetly not done yet.
footballubet Posted March 18, 2013 Posted March 18, 2013 Those pictures remind me of the year I got mine together for the Eastern Meet in Greensburg, Pa. I was still installing interior pieces in the parking lot of the Meet. But I was there! Looking forward to seeing your car at the Meet this year...in 95 days!
CKZ03 Posted March 18, 2013 Posted March 18, 2013 95 days & FOURTEEN HOURS No problem, thats like 3 months-ish, plenty of time
CKZ03 Posted March 23, 2013 Posted March 23, 2013 After 18+ years of darkness & silence, left alone & abandonded my Monte got its first spark of life back today. First time the lights have been on in a LONG time, also the first time its been started with a key in many, many years. Definetly an exciting day. Some of you know I have been working on installing the American Auto Wire upgraded wiring system and recently completed the installation of new wiring in the entire car. Im currently going through each electrical system checking for proper operation, so far all is good. A few pics of wiring in process, believe me Im not really leaving everything looking this ugly. The dash is just temporarily installed for mocking up & routing the wiring, & will be removed until paint work is completed. Charging up my AC system this week & dialing in all the rest of the mechanicals. Glad to get over this hump & moving back onto the paint & body next week.
Mo's70MCs Posted March 23, 2013 Posted March 23, 2013 I don't see anything ugly either, on the contrary I see that as a work of art. The 18+ years of darkness & silence, left alone & abandoned. That's ugly for sure.. Progress is good!
