leelee Posted March 12, 2013 Posted March 12, 2013 Well checked out our wiring job and everything works. WHOOOPEEE Need more help: I read recently about reinstalling the colume and the gear indicators on the cluster. said something about putting in a gear before attaching the little wire and tab on the steering wheel. Does anyone know th precedure? Quote
bigtankjones Posted March 12, 2013 Posted March 12, 2013 I put my column in the lowest gear and the attach the clip/string thing for the gear indicators. Cause with the column mounted and in park. you cant access the the threaded hole to put the screw in. unless you have really tiny fingers Quote
black07ss Posted March 13, 2013 Posted March 13, 2013 LeeLee I thought you had a console? If so there is no indicator wire/string on the column to the dash Quote
