Billu Posted May 27, 2013 Posted May 27, 2013 Not sure if I want to go back with stock spindles. Looking for advice and a few pics of 1". Or 2" drop spindles. Will they work with disc brakes and 15" wheels. I looked through the wheel archive but no info there on dropped spindles. Quote
Sam (Bones) Posted May 27, 2013 Posted May 27, 2013 using drop spindles would be the best choice if you want to lower it, that way you retain your suspension travel and geometry you shouldn't have any wheel issues if they are replacement spindles for the stocks ones Quote
Billu Posted May 28, 2013 Author Posted May 28, 2013 Thanks, Anyone here using 2" drop spindles on their car ? Any pictures? Quote
Slaman Posted May 30, 2013 Posted May 30, 2013 No but I currently have 2" drop springs all the way around on mine. I'm considering adding the drop spindles to get the look I want. I will use the type set-up for stock disc brakes with the ability to upgrade latter. The picture of mine in the primer in my sig is how it looks with 2" drop. Quote
Dans '70 Z20 Posted May 30, 2013 Posted May 30, 2013 Call Mark @ Sevitskes Classic & Customs. He wrote the book on "How to make your muscle car handle". Very knowledgeable guy who is a retailer for just abouT every aftermarket suspension part available. He will help you achieve your goal and stay within a budget if need be. Sevitskes Classic & Customs Dan Quote
Alize LowRod Posted June 5, 2013 Posted June 5, 2013 Thanks, Anyone here using 2" drop spindles on their car ? Any pictures? I am useing them on my 71 Monte. I also upgraded to a bigger spindel and bigger breaks/calapers, so it stops better. I love them. They work great with my Air Ride all the way around Quote
