Mikstudie
Everything posted by Mikstudie
  1. JMO! If you want the best buy the best! MOOG parts are the only suspesion parts that will ever go under my car. Again JMO!!! MIke
  2. Check it!! Most important nobody was hurt! Next important,you didn't hurt the car did you?? MIke
  3. My cousin had a 69SS that came with red lines! I have been searching high and low to find out when Chevy stopped the red line tires! No Luck!! I have never seen a Monte with them from the factory,I dont think it ever happened!I think the cut off was 69. I have a friend that has a 70 SS Chevelle and it was not an option!! Mike
  4. The m22 is the only one called a rock crusher,there are two m22,27splines on out put shaft or 32 splines, the 27 is the rock crusher. The real rock crushers were from 1968-1970 and mostly install in the SS chevelle.This is what I remember from when I put the rock crosher in my Monte.( it came out of a 69 SS Chevelle). Heres some more info! Manual Transmission Identification & Description Manual Transmission Eyeballing Muncie (left) Saginaw (center) Borg Warner (right) To quickly finger what you have, notice in the above picture: The muncie reverse lever is in the extention housing, and the cover has 7 bolts. The Saginaw reverse shift lever is on the cover, and the cover has 7 bolts. The Borg Warner has a 9 bolt cover. Muncies are the hot tip, since they usually were used with high performance engines. Again on the muncie, and looking at the cover, 3rd/4th gear lever is on the left. 1st/2nd gear lever is on the right. Further Muncie identification 3 Muncie 4 speeds were offered. The M-20 wide ratio, the M-21 close ratio, and the "Extra heavy duty close ratio" M-22, also known as the "Rock Crusher". The M-22 was generally installed behind severely powerful (high torque) big-block engines. The M-22 is distinguished from an M-21 by the angle of the gear teeth. The M-22 has "straight cut" gears. Due to this, the box tends to be noiser (whines or howls almost like a blower, which is why it's called a "rock crusher") than other boxes. The M-21 has a higher pitch angle on its gear teeth. The close ratio gearboxs generally came with 3.73+ gear ratio'ed cars. 3.55 geared and higher (numerically lower) cars used the wide ratio gearbox. Due to the wide combination of id's, stampings, numbers, etc... varied and even GM couldn't keep track of what was what, it's best to ID your gearbox visually, taking what is stamped on the box FWIW. The best way to ID the transmission is to count teeth. Muncie 4 speed spline, groove and tooth count characteristics. Type/Year Input Spline Input Groove Input Gear Tooth Count Cluster Gear Tooth Count Output Spline Gear Ratio M20: 1963 - 65 10 none 24 29-22-19-17 27 Note 1 M20: 1966 - 70 10 2 21 25-22-19-17 27 Note 2 M20: 1971 - 74 26 2 21 25-22-19-17 32 Note 2 M21: 1963 - 70 10 1 26 27-22-19-17 27 Note 3 M21: 1971 - 74 26 1 26 27-22-19-17 32 Note 3 M22: 1965 - 70 10 none 26 27-22-19-17 27 Note 3 M22: 1971 - 72 26 none 26 27-22-19-17 32 Note 3 Note 1: M-20 gear ratio: 1st 2.56:1, 2nd 1.91:1, 3rd 1.48:1, 4th direct Note 2: M-20 gear ratio: 1st 2.52:1, 2nd 1.88:1, 3rd 1.46:1, 4th direct, Rev 2.59:1. Note 3: M-21/22 gear ratio: 1st 2.20:1, 2nd 1.64:1, 3rd 1.28:1, 4th direct, Rev 2.27:1 Effective October 21, 1968, an additional letter was added to the plant prefix number to help identify the gear ratios in Muncie transmissions. The additional letter codes as follows: Muncie 3 speed Manual Muncie 4 speed manual transmissions Suffix 1st gear ratio A 3.03:1 B 2.42:1 Suffix 1st gear ratio A 2.52:1 wide range B 2.20:1 close range C 2.20:1 Rock Crusher Of course like engines, transmissions come and go over time, so below is the (as complete as I can make it) transmission plant prefix list: Plant Type Prefix Plant Type Prefix Cleveland Manual Powerglide A Saginaw overdrive O Cleveland Turbo Hydramatic B Warner Gear 3 & 4 speed P Cleveland Powerglide C Muncie 4 speed P Hydramatic Turbo Hydramatic CA Muncie 4 speed R Saginaw Overdrive D Saginaw 4 speed R McKinnon Powerglide E Muncie 3 speed S Muncie 3 speed H Saginaw 3 speed S McKinnon 3 speed K Toledo Powerglide T GM of Canada Turbo Hydramatic L Cleveland Turbo Hydramatic X Muncie 3 speed and Overdrive M Toledo Turbo Hydramatic Y Muncie 4 speed N http://www.chevcarclubvic.org.au/technical/gm_transmission_identification.htm Try this site Mike
  5. I just used a cheap gun looks ok! The insulated pad covers most inperfections,I got a new pad from Cars Inc. looks great!! Mike
  6. Congrats!! Thats a great run!!! Mike
  7. Two 14" Hayden,work great,almost too good!! Mike
  8. Simple thing,but very cool to have,I'am going to get one!! Thanks Capri!! Mike
  9. That 66 is sweet! 71 Monteme,Did you beat you buddy?? Mike
  10. Cool pic,and awsome camera view!! Mike
  11. I have heard the same thing,just dont put dextron in your Ford!! Mike
  12. Just a local auto parts store!I'am sure any parts store can get it, most just don't stock it!! Mike
  13. I special ordered one for a 4 speed Chevelle,nobody had one in stock. Tail shaft mount!! Mike
  14. When I converted my auto to 4speed i used the same crossmember but had to change the mount! Mike
  15. Isn't it still under a drive train warraty??? Drop it off at the Chevy dealer and tell them to call you when it's done. Mike PS: If you screw with it they will void the warranty!!
  16. Thats the stuff,I think I had to modify the push rod linkage to the clutch fork!I cant remember why but I had to!!! Mike
  17. Congrats,thats great news!!!!! Mike
  18. I did a conversion about 10 years ago and had a hard time finding parts. I searched junk yards and found a 69 chevelle and got the parts from it, perfect fit! Iwish you luck in finding what you need!! Mike
  19. Tell me this isn't scary!!!! The locator is very cool! Mike
  20. Carl,sounds real nice. Good job all the way around!Keep up the good work and keep the pics coming!! Mike
  21. http://www.licenseplates.tv/advanced_sea...imageField.y=15 Found some 72 plates but not georgia.Mabey contact them and see if they can help you!!They can also custom make one! Mike
  22. Looks like a lot of fum!! Mike
  23. Very Nice!!!!! Mike
  24. Looks great!!I'am with Ian,I would like to do that to mine!!Someday!!! Mike
  25. You go Jared!!! Mike
