1Bad454
Everything posted by 1Bad454
  1. I found this video the other day. This guy gives good tips.
  2. This post is just what I'm looking for. So to confirm the black part faces inward and the insulation faces the trunk?
  3. Thanks for the advice! Your's looks amazing. I'm trying to get mine to look like yours.
  4. That's a good observation. I'll cut the listing back more.
  5. Mine was marked front and rear. It also had a center line drawn on it.
  6. Those are good ideas gentlemen.
  7. Okay I've been installing my headliner and I think that I would rather get a tooth pulled without anesthesia... Anyways I'm stuck on the drivers side sail panel area.. I can't get the wrinkles out. I've spent hours trying to solve this. Does anybody have any ideas??
  8. Great information Dan! I look forward to your findings. 😎
  9. I'm looking for the best factory replacement seat belt option. I don't have anything to work with.
  10. She's a beauty! 😎
  11. Great info! Thank you sir.
  12. Any recommendations on installation of the headliner? This will be my first time.
  13. What are you guys using for headliner cement. I was trying to avoid spraying it on.
  14. I agree soaking in dawn would be the best. I sprayed mine with clear as well.
  15. Does anybody know what order the headliner bows go in? were they marked from the factory?
  16. Thank you Dan!
  17. I'm looking down on the passenger door. Does anybody have a picture of what the highlighted trim pad adjusting plate assembly looks like? My rigged up setup isn't working.. Basically when I roll the window up it hits the plastic window rub guides.
  18. Does anybody know where the green and yellow wires go?
  19. Thank you Rob!
  20. Are these chrome trim screws or black screws? And what about the vent below? Same screws? Picks would be great to see.
  21. Thank you Joe! As always I appreciate your input.
  22. Do I need to add sealer in the gap areas? Or will the pressure from the window cause the gaps to go away?
  23. Thank you Joe! Just double checking.
  24. I'm looking at the Fisher Body manual and am trying to figure out what the trim pad adjusting plates look like (pg 6-27).. They go where I have an empty spot on my picture. Are they the same as the stabilizer strips?
