patman
Everything posted by patman
  1. THANKS!!!
  2. Yep it's an AC car. The blower has the purple wire and suppressor on it. So the orange wire is for non-AC cars? If so, I'm going to remove it completely from the harness.
  3. Guys, The wiring under the hood is a mess. I've got a good wiring harness to put in it though. Here's were I need help. The only wire that's cut on the harness I'm putting in is also cut on the one in the car. It's in the same bundle that the distributor, wiper motor, starter, and the oil sending unit. It's orange. According to the wiring diagram I have it shows that wire going to the blower motor, but doesn't show me were it connects. The blower circuit is completely different, it has other wires that connect to it. Plus, I don't see any place to attach it the orange one. The car ran fine and the blower works as it should with that orange wire not attached to anything. Anyone got a clue what it's for and where it goes?
  4. Subscribing!
  5. hhmmm I guess that I might as well replace the heads before spending money on a manifold then.
  6. Will an oval port intake fit peanut port heads?
  7. Can I got one of you to post a picture or two of how the kick down cable on a turbo 350 mounts to the engine and discribe how it routes from the trans please.
  8. What has 2 thumbs and called out the carb? This guy! haha Glad you've got it figured out. As far as what to do next, I've done both, rebuilt them and used a reman. Rebuild kits are a lot cheaper than buying a new carb. I'd probably go that route.
  9. Is it a stumble or is it backfiring? It's a big difference. With a stumble I'd say it was the Q-jet, if it's a backfire I'm still going with timing/ignition issue. If it sat for awhile since the last time you started it, there's a chance that the carb gummed up. That would cause a stumble, it may run rich or lean, all kinds of things.
  10. That gasket should work, but I've always used the four hole style. It you sprayed around the base of the carb while it was running and it didn't suck it in, then the gasket was ok. If you've got the four hole gasket already, give it a try. Couldn't hurt.
  11. The problem is that there's no place close that I can get my drive shaft shortened. I live in the middle of now where! haha
  12. Thanks. I don't think I want to get into all of that. Maybe a 200, but probably just another 350.
  13. For you guys that have put one in your car, what's involved with making the swap?
  14. Thanks!
  15. What's the part# on the rack and pinion set up that you have on there? I'd like to do that with mine.
  16. that's what it looks like! sheesh! well I'm going a 200 4r friday that is supposed to be good. I guess I'm going to make the swap a bit sooner than I expected!
  17. really cool thanks the only bolts that line up are the two lower ones right and left. The three on the top have nothing in them. As a matter of fact, the trans doesn't even fully cover these holes! do you have anything like this drawing for the BOP trans?
  18. Any ideas what the heck this trans might be?
  19. Can a sbc be bolted to a pontiac/olds/buick turbo 350? I noticed last night that the only bolts holding my trans to the engine were the two lower ones on each side. So after checking it out more I saw that none of the other holes on the engine lined up to the holes on the trans. Can it be done? Or did chevy change it's bolt pattern somewhere down the line...??? BTW, there doesn't appear to be any kind of adaptor in between them.
  20. patman
    200r4?
    anyone using one? I've heard that there are new stronger parts for them and that they make a great trans for cruising and racing. thoughts?
  21. patman
    Pics
    Good looking car phil. I tried to send you a friend request on your myspace page, but couldn't find it. hit me up!
  22. yeah, that's good stuff....
  23. So that causes to much wall wear?
  24. give it up Sam! what's the scoop?
