LuckyKenny
Everything posted by LuckyKenny
  1. Okay "ummmmmmm........timing... it wasnt adjusted to run on premium so i am juessing that the timing is the same as it was 60 years ago. distributer does have a vacuum advance....dont know if it actually is working. it is hooked up. the plugs are brand new. the floats have been adjusted reciently. i dont know what the boosters are. dont know what a check valve is, carb is like 25 years old. been rebuilt about 1 year ago. Choke???? it has a electric choke that doesnt really work....at all. dont know what ratio the rear end is. 5 speed overdrive tranny.rpm at 50: 1300-1400. the fuel tank is inside the cab of the truck so if it had a leak i would probably smell a lot of gas. i can smell a little in the cab but not a lot. probably do have a gas leak because the tank filler cap doesnt seal the tank properly because the idiot who had the truck before me who also drilled holes inside the cab for a gun rack, he had a locking fuel cap and lost the key to it and took pliers and wrenched it off so the filler is bent. no tranny temp guage but wouldnt you notice the slippage in the rpms??? it does skip 3rd gear. and shift way early in all the other gears. rpms never reach 1500 except in 5th. i just replaced both front calipers because i jacked up my front end the other day and found out that my tires wouldnt spin. took a lot of strength to just turn the tires. that might be part of the reason for the [you said a naughty!] gas milage..dont know yet if the milage improved because i havent drove it. had to take out the rotten break lines and my whole drive shaft because of a blown out universal and midbearing."
  2. I was hey were's the next gear!
  3. I saw the ones that have dual cones with boxes around them I like the holley one too
  4. Thanks!
  5. I can cut holes in my fenders haaha
  6. Thinking about going with a cold air intake/ram air setup This caught my eye any idea's? http://www.jegs.com/i/Spectre/865/728/10002/-1
  7. Good glad i'm not crazy haha
  8. haha no!
  9. Stock TH350 The guy that sold it to me was either a liar or a moron He said it was a 700r4 the pan is square with a cut, TH350 correct?
  10. So did i
  11. It's a 350 from a vette with a 700r4 We're both pretty sure it's got stock heads and everything. It has a 4 bbl holley and an eldebrock intake. He gets literally 5 mpg and drives like an old man. I get about 3 times better mpg's with a stroker, quuadrajet, preformer intake and cam, and new heads. What's his problem? stock heads 4bbl? Help??
  12. Okay so i've noticed ths slight hum coming from the tranny whenever i floor it in 3rd gear from like 50-75mph. Is it the tranny slowing down untill it can downshift or do i have a problem. Maakes the same sound if i downshift manually. I rarely do 3rd to second gear pulls anymore so i was wondering if there was something wrong. How's everyone doing anyway??
