I had the exact same thing happen last weekend. When I jumped the car it started right up. The prior owner had put on a fuse in place of the fusible linkIand the wire connection ant the cable was a bit flakey. I replaced the positive cable, fusible link and have ordered a new negative cable. I hope that fixes my problem. One question I have is what should the amp guage read when running?
That makes sense Bob, i put a bike pump on the lime and just pumped it a few times, low pressure. So if I put a vacuum pump on the line, should it hold steady pressure.
Another air ride compressor question, does the vacuum line from the engine push air to the compressor or suck air from the compressor? It sounds like a dumb question but I pumped air pressure to the manual valve and the rear valve and shocks seem to work fine. I the tried to pump air into the compressor and it seems to come out the vent or overflow. I'm not sure how to make sure the compressor isn't leaking. Any help would be great. Thanks
Carl, the Cable for a 3 speed with heavy duty or 4 speed is PN# 6478178, 72" long. The cable for a 3 speed (exe HD) is the same PN# 6478175, 60" long. These are the listings in the parts catalog for a Chevelle. I don't think a 3 speed was put in a Monte. I hope that helps
Sam, I reset the mixture screws and reset the idle, runs great. The prior owner must of done the 1 1/2 turns. I will still be checking the timing, thanks
If the wrong PCV valve is used, can it cause the car to idle improperly? The car came with the wrong valve in it (CV682C). I ordered a CV736C which should be the correct valve. When my car comes off of high idle after I start it, the car seems to want to die at stops. If I drop it into neutral it runs fine. Any ideas????
I'm not sure what the clips look like but I just ordered a few different clips and retainers from this company: AMK Products Inc.. Look at the bulk items link. Good luck
http://www.amkproducts.com/
