TheBMan Posted March 5, 2023 Posted March 5, 2023 My 1970 has the small (narrow) radiator with the 3-bolt radiator support topper as opposed to the wide radiator and 4-bolt topper. (picture attached). As you can see, the upper hose fits very poorly. I cannot find an alternate/correct hose. @FrankOC mentioned that this has been discussed on this site in the past but my searches have turned up nothing. Is anyone aware of a hose supplier or a way to trim this hose to fit properly? I can take a shot at it (trimming) but I'd rather not butcher a hose via trial and error if someone knows the method. Quote
Rob Peters Posted March 5, 2023 Posted March 5, 2023 Do you have your old hose? If you did you could use it as a template to cut the new one to fit better. rob 1 Quote
jft69z Posted March 5, 2023 Posted March 5, 2023 The hose is 'trim to fit'. Trial and error is about the only way, but remember....measure twice, cut once. I seem to recall years ago there would sometimes be a line marked on the hose if it were for multiple applications, but still wouldn't trust that without checking the fit first. 2 Quote
TheBMan Posted March 5, 2023 Author Posted March 5, 2023 6 hours ago, jft69z said: The hose is 'trim to fit'. Trial and error is about the only way, but remember....measure twice, cut once. I seem to recall years ago there would sometimes be a line marked on the hose if it were for multiple applications, but still wouldn't trust that without checking the fit first. @jft69z Yeah, in hindsight I feel somewhat silly for asking if anyone has a "method". I'm completely capable of trimming the hose. LOL 3 Quote
TheBMan Posted March 5, 2023 Author Posted March 5, 2023 7 hours ago, Rob Peters said: Do you have your old hose? If you did you could use it as a template to cut the new one to fit better. rob Unfortunately, no. I briefly considered upgrading to the larger radiator (just because) but my core support doesn't accommodate the 4-hole top plate. Besides, my 'standard' radiator is a 3-row unit so it should be more than adequate. Quote
DragCat Posted March 5, 2023 Posted March 5, 2023 When I did my engine swap I ordered new hoses from Summit. And yes I did the check if it fits your car 🤣 The top hose was way to long and had to trim it. 2 Quote
Canuck Posted May 3, 2023 Posted May 3, 2023 Sorry for the late reply on this. I have never been able to find the hose for the smaller rad. I cut it on the end that fits on the rad and just keep cutting until it fits decent. It is usually part way into the curve where I end up. 1 Quote
Canuck Posted May 3, 2023 Posted May 3, 2023 On 3/4/2023 at 8:52 PM, jft69z said: The hose is 'trim to fit'. Trial and error is about the only way, but remember....measure twice, cut once. I seem to recall years ago there would sometimes be a line marked on the hose if it were for multiple applications, but still wouldn't trust that without checking the fit first. I believe there actually was a separate part number to begin with but I assume with the small rad Montes being pretty uncommon the manufacturers don’t bother to make the correct hose. Quote
