350_inside Posted September 1, 2015 Share Posted September 1, 2015 Simple question, im swapping out my 10 bolt for a 12 bolt, do i need a new driveshaft or are they the same ? Quote Link to comment Share on other sites More sharing options...
Bluemalibu Posted September 1, 2015 Share Posted September 1, 2015 It is very probable that no change will be necessary... The reason that one can't be more certain, is that the pinion yoke in the rear end can be easily changed. You might find a 1310, 1330 or 1350 yoke in either differential. And short, medium, and long shaft yokes are available in each flavor (size) as well. That being the case, should the yokes be different, you can swap in the correct one instead of making the change to the drive shaft. Quote Link to comment Share on other sites More sharing options...
