201fireman
Everything posted by 201fireman
  1. I am taking on the interior of my 72 this winter. Where is a good place to but foam and seat covers for my Saddle buckets? I will also need a headliner so I am assuming I can get that at the same place. In regards to the headliner... try it myself or stay away from it and just have someone do it?
  2. For those with electric fans, do you have them wired to keyed power so they go off when the key is off or direct 12 volt so they keep running after the car is shut off?
  3. Ok, I have my gauge exactly where you do as well. The sender for the fans is in the head and that's the one I am thinking of moving to the manifold by the Tstat.
  4. I have a small block in my 72. It has two electric fans and an electric Automater temp gauge. The gauge has a sending unit and the fans have a sending unit. Right now I have the sender for the fans in the PS head and the sender for the gauge in the back of the manifold by the distributor (just did the gauge one this spring). I see some people putting them in the head and some in the manifold by the Tstat. I am assuming I would want to put both sending units in either the manifold or heads and not one in each as it is now. My question is, what is the better spot? I am guessing the heads would have exhaust heat that makes the area read hotter which would be in a sense, a false reading?
  5. I have a 72 Monte with an Eaton Truetrac 12 bolt, series 3 posi and 33 spline Yukon axles. I am looking at a set of 3.73 ring & pinion gears out of a 70 Chevelle 12 bolt. They have the part number 3862525 stamped on them. Will these work in my unit?
  6. Any thoughts on Evans Waterless Coolant? I took my engine out over the winter for some upgrades and it's time to put it back in. This stuff looks nice but is it legit for the cost?
  7. Did any of you guys put some sort of power block or junction box under the dash so you don't have to run so many wires to the fuse panel? I have the Autometer UltraLite II (LED) gauges and they have 2 ground, 2 power, and a sender wire for each. I am going to run all of the grounds together to a solid ground under there. I am thinking of mounting a power distribution block or something to run all of the power wires to and then just feed that with one wire from the fuse block. Any thoughts?
  8. Gotcha. Thank you. It seems like it is almost a 50/50 split when I read things online or look at instructions on which on is the feed and which one is the return. I am almost wondering if it doesn't matter.
  9. I am installing a cooler to add to the current stock cooler. I have looked all over online and even on here and it seems almost split on which line is the out and which line is the return line on a TH350 trans. Even TCi and B&M are opposite. TCI says bottom out of trans to bottom into radiator, and top of radiator is the return to the trans and B&M says the top of trans is the output to top of radiator and bottom of radiator is return to trans. If anyone knows for sure please post... Also, I am adding a trans temp gauge with an Autometer manifold in line to read the temp. Where do I read the trans temp? Do I install the gauge manifold on the hot side or on the return line after the fluid is cooled to measure fluid temp?
  10. Awesome to see on My Classic Car!! Way cool.
  11. That's my thoughts exactly. I just wanted to make sure I wasn't missing another way to do it. Thanks!
  12. Hello, can anyone confirm that the transmission cooler lines on a 72 small block TH350 are 5/16" lines? I installed a B&M cooler when I put a stall in and I am adding an Autometer trans temp gauge. I need to add the manifold below to hold the sending unit. Also, is this the best way to make the gauge work or is there a better way? They are pretty proud of this manifold judging by the price. Another thought, if I am spending $52 for a manifold, would it make sense to upgrade the lines and if so, what set-up would be recommended? https://www.summitracing.com/parts/atm-2287
  13. I am looking into a fuel pressure regulator and am curious what others are using? I have a small block with a mechanical pump. Curious if others are using a return or non-return style? brands? Pressure ranges? Etc. Any thoughts?
  14. This helps alot. Thanks!
  15. Freshened up a friends 1970/454. He bought a new engine wiring harness from M&S Wiring (part number 15100). We are having problems figuring out where these wires go. They are on part of the harness that comes through the wiring gutter on the firewall and goes to the passenger's side. It was a mess when we started so we have nothing to go off of. Below are two pictures. Any help with where they might go would be great. Thanks!
  16. Yes, I unhooked the throttle cable as well as the kickdown cable so there is nothing hooked to the carb and it still does it. Like I said, when you shut the car down, it drops the rest of the way right away.
  17. I promise I wasn't the one who rebuilt the one you bought lol! This bugs me because it didn't do it until I rebuilt it.
  18. I have an Edelbrock 800 AVS. I rebuilt it and now it runs beautiful but the throttle will not return all the way. It comes back to very close, about 1100RPMs but I can then push it manually back to about 850. I don't believe the linkage is stuck or the plates are binding or hitting because if I shut the car off, I can literally watch the throttle linkage settle the extra 1/16" immediately. Then when I start it, it is back to normal until I rev it again. I also backed the choke off all the way while it was at the "high" idle and that didn't help either. I took the carb off and checked everything and it all seems good. Any thoughts? One more thought, after manually pushing it back to the 850RPMs, when I back out the idle screw all the way, the car slows down and dies, which tells me again that I don't think anything is binding.
  19. Thanks for your input Paul! I also have been looking into these the last couple weeks. Did you end up buying one and if so, how did it work? I am curious as to the difference one would make over my Edelbrock Thunder Series AVS with the ever so popular hesitation at the start. Your post was very informational and appreciated!
  20. Ok, thanks! Just trying to clean out what I don't need without A/C.
  21. I am removing the A/C and cleaning up the wiring under the hood of my 72 small block. The part pictured is on the passenger's side firewall. Can anyone help me identify what this is for and if it can be removed? Thanks!
  22. My originals ones were 30 spline and my car is a small block. The Truetrac works great. I am at around 450 HP and run 3:55 Richmond gears (12 bolt) and haven't had any issues. Haven't ran it at the track though, just street use.
  23. If you haven't found them yet, I just put a Truetrac in mine this past year and I bought Yukon 33 spline C clip axles from CrazyDavey on this site for a very reasonable price (new).
  24. I believe our Montes (mine is a 72) came with a 1 1/8 bore master cylinder. Would a 1" bore work also or would it not fit or be a negative effect?
