Looking for measurements
I’ve been looking for a couple measurements I haven’t been able to locate.
— How wide is the wheel well lip on a factory quarter panel?  Are aftermarket quarters typically wider there ?
—   What is the dimension from inside that wheel well lip to the inner fender near the frame?
                                   Thanks 👍
Tim,
The answer to your third question is 13".  Someone else will have to answer your first and second questions.
1 hour ago, MCfan said:
Tim,
Thank you, that definitely helps. Mines about 12 5/8” - 12 3/4”.     I get exactly 2” to the back of both wheels from the inner fender by the frame, so I’m guessing my quarters are a little wider on the lip.
