Guest Posted July 4, 2006 Share Posted July 4, 2006 Alright. I have a new problem now haha. Ok so a couple of weeks ago i had the car al finished or so i thought! until i found out that my rear brakes dont work.so i left the car for a while until i could ge tthe money for it. so a couple of days ago i just started up the car and let it warm up a bit and decided to run through the gears on the trani. But when i put it down into a gear ex. reverse, drive etc. it will stall out on me. I cant figure it out! Whether it is timing or something with the trani. Now i havent touched the distributor or anything. So i am stumped. Any help or suggestions?!?!?Thanks, Chris Quote Link to comment Share on other sites More sharing options...
Guest Posted July 4, 2006 Share Posted July 4, 2006 When is the last time this car has had a complete tune up? Quote Link to comment Share on other sites More sharing options...
Guest Posted July 5, 2006 Share Posted July 5, 2006 If it stalls out when you hit the brake pedal I am willing to bet it is the battery, or the alternator is not charging well. Andreas will remember I had that problem when the battery went kaput on me. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 5, 2006 Share Posted July 5, 2006 Ok. Well the last time the car has had a COMPLETE tun up was a little while ago but the plugs are fine. And i am in the middle or ordering a new HEI cap and wire set. The car has had an oil change about 2-3 weeks ago and i just changed the trani fluid. Which needed to be changed. Now pete, The battery is accualy dead. I have to keep boosting it to get the car started. So maybe when i boost it, i could leave to cables hooked up to my other car and then just see if it will go into a gear without stalling???Do you think that will work? or should i just go and get the battery charged? thanks guys, Chris Quote Link to comment Share on other sites More sharing options...
Guest Posted July 5, 2006 Share Posted July 5, 2006 Well it's sounds like you need a new bettery any way so I think you should buy one and see what happens and go from there. 2 cents Quote Link to comment Share on other sites More sharing options...
Guest Posted July 5, 2006 Share Posted July 5, 2006 Sounds good to me. Thanks alot. I will hvae to give that a try and see what happens!!!! Quote Link to comment Share on other sites More sharing options...
