NDSopp Posted August 2, 2023 Share Posted August 2, 2023 I replaced the HVAC controller in the dash with new after a mechanic told me that was the problem. It wasn't, the air doesn't redirect from the floor to defrost or dash vents when adjusting controls. I did find that when the carburator and intake were replaced with a Holley Sniper EFI the vacuum line to the controller wasn't hooked up. I hooked it up and tested the check valve on the firewall. It still doen't rediredt air. The Hot/Cold slider does work, the fan switch is new and works. My thought now is look at what the HVAC controllers vacuum portion is connected to. This is where I need help with a vacuum schematic or shop manual notes. Help...it's even HOT in North Dakota. Quote Link to comment Share on other sites More sharing options...
