Guest Posted July 25, 2004 Share Posted July 25, 2004 Is there a different torq ue converter for a 350 turbo for a big block and small block? I have replaced my 350 engine with a 454. My goal is to install a 700r4 this winter, but for now I would like to use the 350 turbo behind the big block so I can at least make a couple of cruise ins before winter. The 350 turbo needs rebuilt along with a new torque converter. I plan on eventually rebuilding the 350 turbo to use it behind the 350 small block that I removed from the Monte for a future project. So--- is the torque converter the same that I will need for the big block versus small block application? I just don't want to spend 200 bucks for a converter behind the big block just to be able to make a couple of cruise ins. But if it is the same converter then I can use it behind the small block later. Make sence????? Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted July 25, 2004 Share Posted July 25, 2004 You can use it. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 26, 2004 Share Posted July 26, 2004 Thanks a bunch George!!! I knew you could help me out, I appreciate it! Quote Link to comment Share on other sites More sharing options...
