bdk70monte Posted August 13, 2009 Share Posted August 13, 2009 I am currently running a Turbo 350 trans with 3.73 rear gearand a ZZ4 350 Fast Burn 385 HP motor in my 70 Monte. In an effort to make it more highway driveable, I wanted to go to an overdrive transmission. I recently found a good deal on a 200-4R out of an 85 Monte SS, so I bought it. I know some of you are running this trans, so I just wanted to check and see if you had suggestions as far as what all I should look at upgrading when I get it rebuilt. I will plan to do the usual with a shift kit and things like that. Just wondered what else works well with our cars. I plan to replace the rear gears down to an original 3.31 posi set up as well. I would also like to continue to use this trans when I drop the 402 big block that the car originally had in it back into the car. The motor will probably be a fairly stock setup in appreance at least with some possible upgrades that are less conspicuous. I figure if I get the trans rebuilt to handle up to 450 HP I should be ok, and probably 400-500 ft. lbs. of torque with the big block. Thanks, Ben Quote Link to comment Share on other sites More sharing options...
Mr70Monte Posted August 14, 2009 Share Posted August 14, 2009 here is a guy's website, http://www.ptsnctb.com/ that knows what he talking about when it comes to building a 2004R, on his site, top center of the page, click on "Strenghtening the 2004R". Quote Link to comment Share on other sites More sharing options...
