Chevyss Posted May 6, 2010 Share Posted May 6, 2010 I've been browsing through the NHRA hand book and reading up on all the different class'. Not really which class the Monte would fall in. Stock, Super Stock???? Thanks in advance Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted May 6, 2010 Share Posted May 6, 2010 Royce it really won't fit into either of those classes....those are hardcore classes (you know like the ole Don Nickelson days). If your at an event that's not just a test and tune then you will choose between what that association runs. Like Summit ET series for example...they run 4 classes....High School (sorry buddy you're too late for that one)...Sportsman (12.00 to whatever)...Pro (9.00 to 13.99) and Super Pro (7.00 to 12.99) Depending on what your car is running sometimes you can run multiple calsses if you want to (get more hits that way)...in this case you could run all 3 if you car was running 12.10's for example. Just make sure your car is NHRA legal for the ET's you think it could run and there will be some kind of class you will fall into. Neither of us have the money you would need to run NHRA stock or super stock, those classes are nuts.... Section 4 in the book is mostly directed at guys like you and me.....Davey Quote Link to comment Share on other sites More sharing options...
Chevyss Posted May 6, 2010 Author Share Posted May 6, 2010 Thanks Dave It's research time. Hopefully the 7th might be the one. Little trans problems my hold it up. Sportsman sounds good. Quote Link to comment Share on other sites More sharing options...
