ejw71 Posted October 8, 2003 Share Posted October 8, 2003 My 71 454SS has a radiator overflow catch can. Suspect it's an aftermarket item. Did radiator overflow to ground through a rubber tube that was attached just below cap or was a catch can used? Thanks, Ed ------------------ '71 Black 406/700R4/10bolt, Branson participant '71 Sandalwood SS454 '71 Project Darkest of Dark Green Metallics/GenIII346LS1/4L65E/12bolt posi Quote Link to comment Share on other sites More sharing options...
Guest Posted October 8, 2003 Share Posted October 8, 2003 First generation M/Cs did not have a coolant recovery system standard. When the coolant level rose, any excess would drain to the ground through the tube you referenced. A coolant recovery system was a dealer-installed option for our cars. The recovery bottle's holder bracket mounts to the right inner fender well. I picked up one of these GM accessory kits a couple years ago. The kit also includes a different radiator cap. ------------------ Mike '72 Monte Carlo Custom '74 Buick Regal '99 Olds Aurora Quote Link to comment Share on other sites More sharing options...
ejw71 Posted October 8, 2003 Author Share Posted October 8, 2003 Tks, Mike. Mine is attached to right fender (not inner fender and looks aftermarket)next to battery. Ed Quote Link to comment Share on other sites More sharing options...
