72 chevelle cluster
jsantoro
hi can someone help i have a 72 chevelle with the sweep gauges trying to put the ss round gauges does anyone know if the old harness will work or do i need a new harness for the round gauge cluster, thanks
Hey Joe, You will need the correct Harness for that dash. There are two different harness's,one for Tach and Gauges dash or the harness for the Idiot Light dash as they are called that are still round and then you will need to relocate about 5-6 wire locations down at the fuse block under the dash to accomidate either harness you are putting in. It is not un plug and plug straight in on a Malibu to SS style Dash, if you were to try you can end up with a blown fuse and then turning signals not working and or both turn signal lights in the dash illuminating and staying on when dash lights are turned on and a couple of other oddities...
Darren.
