snomobeelr Posted June 19, 2015 Share Posted June 19, 2015 I have a CVR vacuum pump for my brakes since the motor is not creating enough vacuum. Kinda wish I had done the hydro-boost may do that later. Anyhow I have the pump installed next to the battery. I bought a vacuum canister thinking that would be good for reserve if needed and I mounted where the charcoal canister used to be. Then to the Power booster. So the vacuum line went from the vacuum pump - to the check-valve in the vacuum canister out the canister to the Power Booster. Issue was the vacuum pump was running all the time didn't shut off. I figured I had a leak in the canister so I now have it running directly from the vacuum pump to the Power booster.. If I drive the car this way will the pump keep up with the braking while driving ? Or do I have the potential to lose power braking? Thanks Quote Link to comment Share on other sites More sharing options...
70 Iron Posted June 20, 2015 Share Posted June 20, 2015 I think you'll be fine with your set up,they don't call for a additional canister. I had the canister in line you had also and great brakes however the vacumn pump vibrated so much thru the car,steering whl ect I pulled it back out and just using the additional canister and works fine .It also ran a lot. The pump came with rubber mounts but still was terrible on vibrating.Mine was mounted behind the washer bottle to the plastic inner fender. Terry Quote Link to comment Share on other sites More sharing options...
