Guest Posted March 23, 2006 Share Posted March 23, 2006 or do i just need to fill up the trans? when i took apart my last engine and transmission, a lot of trans fluid came out of the torque converter upon removal. was it filled up prior to installation or does it full up with use of a well oiled transmission? i have a 700r4 transmission with a 2400 stall speed lock up converter. the engine is a 400 horsepower 350 small block chevy. thanks Quote Link to comment Share on other sites More sharing options...
502ci Posted March 23, 2006 Share Posted March 23, 2006 YES Quote Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2006 Share Posted March 23, 2006 okay, is there any special trans fluid i need to use? how much fluid should i use? is there any special thing i should know? or simply just pour it in until it's full? thank you. Quote Link to comment Share on other sites More sharing options...
502ci Posted March 23, 2006 Share Posted March 23, 2006 I was afraid you were going to ask. This is not my speacilty (transmissions that is), someone will come to help I`m sure. But I do know you fill them first. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 23, 2006 Share Posted March 23, 2006 i just read online that i should use about a quart of fluid, and to pour it in slowly, because it doesn't take fast. if this is wrong, or if there's anything else i should know, i'd appreciate the infomation. thanks. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 24, 2006 Share Posted March 24, 2006 as you pour the fluid in, and it looks full, spin the converter like a top, then it will take more fluid. do that about 3 or 4 times and you are good to go. also, put a little white lube or red grease on the converter hub and on the front seal of the transmission before you put the converter in. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 24, 2006 Share Posted March 24, 2006 thank you much. Quote Link to comment Share on other sites More sharing options...
