mc71454 Posted March 6, 2004 Share Posted March 6, 2004 Here is an Excel Spreadsheet that will calculate the Valve Spring Pressure of any spring when you know the Height and the corresponding Pressure at two points. It will also calculate the maximum lift of your Cam at a particular installed height if you know where Coil Bind is. The factor of safety used for Coil Bind is 0.060” and can be changed if desired. http://www.boomspeed.com/mc71454/mc71454_spring_rates.xls Right Click and “Save Target As” Please Inform me if there any problems with it. Thanks Link to comment Share on other sites More sharing options...
