Guest Posted September 29, 2003 Share Posted September 29, 2003 Hi,Looking for advice for removeing the trim around the bonet top on a 70.Is there a special tool required for this or is there a trick i should know before i get the hammer and chisel out The tops in great shape but the rust bubbles underneath are driving me nuts...so....off it comes..going to clean it up, use the por-15 and put a new top on...The trim's in great shape...I just want it to remain that way. Thanks in advance RCR Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2003 Share Posted September 30, 2003 I hope someone can give you some good advise, or you can check out the bottom of this thread http://www.firstgenmc.com/ubb/Forum14/HTML/000053.html ------------------ <IMG SRC=\"http://... LLOYD@firstgenmc.com Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2003 Share Posted September 30, 2003 Thanks ADGTRUNKLID, That putty knife trick sounds like it might work..A nice flat surface to not damage the trim. i wonder if there are clips under the trim...I guess there would be.... ------------------ RIDES 2002 Dodge Ram Sport 1970 Monte ss 454 (Clone) http://www.cardomain.com/id/rcr0001 Link to comment Share on other sites More sharing options...
Chris Posted September 30, 2003 Share Posted September 30, 2003 Yes, there are plastic clips under the trim. Also, the 2 rear corner pieces (near the trunk lid) are held on by nuts from underneath. Beware of what you may find under the bubbling vinyl. I was planning to do exactly what you are but discovered a severly damaged portion of the quarter piller and on the trunk filler due to a previous owner (pre-1980) botched repair. Chris Link to comment Share on other sites More sharing options...
Guest Posted September 30, 2003 Share Posted September 30, 2003 Quote: <font face="Verdana, Arial" size="2">Originally posted by Chris:Yes, there are plastic clips under the trim. Also, the 2 rear corner pieces (near the trunk lid) are held on by nuts from underneath. Beware of what you may find under the bubbling vinyl. I was planning to do exactly what you are but discovered a severly damaged portion of the quarter piller and on the trunk filler due to a previous owner (pre-1980) botched repair. Chris</font> What he said. Also, the trim around the glass needs another tool. It is shaped like a flat arrow to reach under the trim and pull the clips off the trim. Those clips just hook on the edge of the trim. You can get them at any parts store. Link to comment Share on other sites More sharing options...
Guest Posted October 4, 2003 Share Posted October 4, 2003 Thanks guys..appreciate the advice\info..It's startin to get cold up here so it's time to tare it apart and spend some money. RCR ------------------ RIDES 2002 Dodge Ram Sport 1970 Monte ss 454 (Clone) http://www.cardomain.com/id/rcr0001 Link to comment Share on other sites More sharing options...
ejw71 Posted October 4, 2003 Share Posted October 4, 2003 RCR001, The rear corner pieces, as explained above, are bolted on with two bolts per item. Bolt nuts, 3/8", assessable via trunk, underneath package tray. The corner pieces are cast metal and break super easy. Ed ------------------ '71 Black 406/700R4/10bolt, Branson participant '71 Sandalwood SS454 '71 Project Darkest of Dark Green Metallics/GenIII346LS1/4L65E/12bolt posi Link to comment Share on other sites More sharing options...
