GatorDog72 Posted September 15, 2015 Share Posted September 15, 2015 When using an MSD trigger box, the coil input wires see something like 400-500v, if I understand it correctly. Would the higher voltage on these wires cause interference with the rest of the harness? Should I isolate or shield the coil input wires away from the rest of the chassis/engine harness, or am I wasting my time? I have the box installed inside the car, and would prefer to have all the wiring come out one hole on the firewall if possible. Quote Link to comment Share on other sites More sharing options...
GatorDog72 Posted September 17, 2015 Author Share Posted September 17, 2015 I just got off the phone with MSD on this issue and it apparently makes no difference where the coil input wires get routed. However, the magnetic pickup wires (green/purple) ARE sensitive to interference and should be kept away from any electrical noise. They also sell a shielded cable for this circuit. I should have probably mentioned the box I'm running is a 6AL-2 Programmable. Should be pretty much the same for any 6 series box. Hope this info helps anyone trying to install one of these. Quote Link to comment Share on other sites More sharing options...
