chuckash Posted May 2, 2002 Share Posted May 2, 2002 Riceracing made a recommendation to me about a holley intake to consider using on my 400 small block. It is a p/n 300-25. Is anybody running that manifold on a first gen monte right now? If so, did you have hood clearance problems? What other manifolds are you folks running, with or without hood clearance problems. Using the internet, I can probably find out manifold heights for comparison purposes. Before I spend some money on an intake, I just want to make sure that there won't be any surprises. I'm not ready to go the cowl induction route yet. Charlie Link to comment Share on other sites More sharing options...
Pirate Posted May 2, 2002 Share Posted May 2, 2002 I use a Performer RPM on my 454. However, I also use a dropped base air cleaner, so clearance is no problem. Pieter Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2002 Share Posted May 2, 2002 Chuck, I have run that before in a first Gen. with a 4" tall 7/8" drop base air cleaner with no clearence problems at all. Don Link to comment Share on other sites More sharing options...
