MC350 Posted July 9, 2005 Share Posted July 9, 2005 Hey Fellas what is the gap setting for the 72's points I thought it was 19?? What works best for you I have a vibration at a stop light but then if I get rid of the vibration to get it real smooth..it will hesitate on take off I cant find a happy medium Maybe I'll just start over...anyway any info will be much appreciated Link to comment Share on other sites More sharing options...
Guest Posted July 9, 2005 Share Posted July 9, 2005 Hey Ray, Yes, you are right 0.019 in is correct for new point's but, try setting them at 0.016 if not new. Check your dwell should, be between 29-31 degrees also, check your wire's especialy at the boots and distributor cap for cracks.Any vac/leaks ? Link to comment Share on other sites More sharing options...
dmdbit Posted July 9, 2005 Share Posted July 9, 2005 Mc350 One thing to remember is that as dwell changes this has an effect on timing.Set your dwell at as papa joe mentioned and then set your timing. mike b Link to comment Share on other sites More sharing options...
